Like Tree2Likes
Go-Tech Engines Thread
Old 11-17-2007 | 10:47 PM
  #466
A.C's Avatar
A.C
Originally Posted by Jason Halvorson
i would remove the carb and silicone it on...this should help with the carb wanting to rotate...
hi, i am thinking of getting a .28 GO.
just afew question, does the .28 comes with a Turbo head and why izit that the CARB will rotate and or come loose?
compare between .21 5port and .28 6port which is better for the 8T?
cheers.
A.C is offline
Old 11-17-2007 | 10:56 PM
  #467
Jason Halvorson's Avatar
cheers.
the turbo head is still in testing and not available for retail yet...as for the 21-5 or the 28-6, i would go with the .28...this engine is very strong with mass bottom end, just what a truggy needs, but either way you go you will be very happy with the Go engines...
Jason Halvorson is offline
Old 11-17-2007 | 11:14 PM
  #468
A.C's Avatar
A.C
Bro, just wondering abt the CARB too. why izit that it will drop off or rotate?
do we have to do it everytime we get the .28 6port new?
A.C is offline
Old 11-17-2007 | 11:20 PM
  #469
A.C's Avatar
A.C
that was the first time i have ever heard of it happening...the .28 that i run the carb is nice and tight, and has never moved...
phew, that set my mind at ease...
thks for the info thou.
A.C is offline
Old 11-17-2007 | 11:24 PM
  #470
Old 11-18-2007 | 06:06 AM
  #471
Never had a carb move like this before. I'll let you all know if the silicon does the trick.
GuyHuey is offline
Old 11-18-2007 | 07:21 AM
  #472
Brandon Melton's Avatar
As far as fuel mileage questions that people are asking, I saw something this weekend that blew my mind. I timed a fuel run for my buddy's car using a turbo 5 port and he went almost 13 minutes in a Losi 8ight with regular fuel tank. 12:52 to be exact. This was at 238 degrees.
Does anyone know if the fuel tanks on the RC8 are smaller than the 8ight? Cause I don't get that mileage with mine, LOL. I can go 9 minutes at similar temps, piped the same.
Brandon Melton is offline
Old 11-18-2007 | 08:32 AM
  #473
both cars have a 125cc tank, but even 9 minutes is outstanding...alot if it has to do with driving styles, even the outdoor temps can make a huge difference from day to day...
Old 11-18-2007 | 03:07 PM
  #474
Where can I get the carb inserts for the GO 21's?
BTW I got 9 mins and 38 secs on a tank today.
Lon_L is offline
Old 11-18-2007 | 03:16 PM
  #475
email Russell at Race Factor [email protected], and he can hook you up with a carb insert kit...
Lon_L that is great run times...
Old 11-18-2007 | 06:34 PM
  #476
salteen's Avatar
I ran my 7 port some today. It seems like it is tuned great after leaning it out some but everytime I hit it with the temp gun it wasn't abover 200. It was running in the 190s and it's acting like it doesn't want to be leaned out anymore. After I lean out the high end an hour or two it bogs at WOT and richening the low end didn't seem to help with the wot bog...the only thing that helped was richening the high end back to where it was. I still suck at tuning, I'm sure I'll get it sooner or later but maybe you guys can help me out some.
...I was using an OS p4 today but it acts the same with the p6
salteen is offline
Old 11-18-2007 | 06:48 PM
  #477
are you still running the extra shim??? if so it may be time to take it out...
Old 11-18-2007 | 06:55 PM
  #478
salteen's Avatar
I haven't added any shims if that's what you mean. Are there extra shims installed from the factory?
I've been running 20% until I feel it's broken in good enough. It's still uber tight after 9 or 10 tanks.
salteen is offline
Old 11-18-2007 | 06:58 PM
  #479
the engine comes with an extra shim in the box...this extra shim is used during the break in to help with how tight the Go engines are...
Old 11-18-2007 | 07:05 PM
  #480
salteen's Avatar
I screwed the pooch on that one. I didn't get the manual with my motor though, so that doesn't help things.
I'll have to get that shim in there, it really needs it. I thought it was there to add if running 30%...
salteen is offline
