Seattle RC Racers/Hangar 30
never got called into work. but got to work on the car today. found some really weird setup on the car and changed it back to more like the standard setup. little tweak here little tweak there. from what it was set up like it was at the most docile settings. way more docile than standard. hopefully it will drive better and be faster. got walked on last weekend at the cc. didnt enjoy that.
I had a good time last night, for my first time driving an on-road car. Here are the videos I took of the races.
SRCR Novice
SRCR Stock TC
SRCR World GT
SRCR Scale Spec
SRCR Stock 1/12th
SRCR Novice
SRCR Stock TC
SRCR World GT
SRCR Scale Spec
SRCR Stock 1/12th
Need loaner receiver for NORA this weekend
Hi guys,
Anyone going to NORA this weekend? My Spektrum 3100 went down and my new receiver won't arrive until Monday the 3rd of March. I'm in need of a loaner if anybody has one available. Just trying to get some practice in up there.
Thanks,
Jerry B.
Thanks,
Jerry B.
1. Leave the glue flange about 3mm longer than the trim line. Then trim back to the trim line only where needed, on the side where the splitter comes in. The extra flange gives more surface to improve the glue's hold.
2. If you are going to paint the nose before assembly, mask off the portion of the nose piece that is backed up by the glue flange, so it won't be painted. This gives the glue better hold, and the flange will be painted so you won't have a clear band on the nose. You can also put the nose on before you do any painting. In that case, be sure to peel the film off of the glue flange!
3. Drill the holes as indicated on the flange and perform a test assembly. Do not tighten the screws fully.
4. Remove the nose, apply shoe-goo to the flange, then put the nose back on with the screws. Even though this is the final assembly, barely snug up the screws. If you tighten them more, all you'll accomplish is cracking the plastic (especially on the flange sides where the lexan is thin) and weakening the front end.
The whole thing is a pain, but the nose does stay on and the body is a good one. Protoform has to make the body in two pieces because they can't do the multi-part body molds that Tamiya and HPI use on their realistic bodies.
Last night was fun! Thanks Kyle for taking on the RD duties and making this program possible this season.
The hangar track is great fun with a Stock 1/12th scale. It's tight and technical and calls on the best of what 1/12th scale has to offer. At the same time, being Stock, the wear and tear is really minimal. That was the third night with a single set of tires, and I'm thinking I've got at least one more to go. Actually, one more no question. It's the two more that gives me pause. At any rate, that's two months of Hangar action on one set of tires. Cheap fun! There are a few bumps, but truly, they don't detract from the experience. If anything, it's further evidence that 1/12th scalers, when reasonably powered, are highly adaptable machines. A track doesn't have to be perfect to have a great time.
The other classes went well, too. Great racing Mark and Lem in Scale Spec!
Sweep vs. Solaris
Hi all,
I'm thinking about trying Solaris tires for Mod Sedan. I've been running Sweeps all season, and Jaco Blues are not available... anywhere
Any thoughts on the Solaris tires? As I understand it in the rules, Sweep, Solaris and Jaco brands are all legal to use in Mod Sedan.
Thanks a bunch dudes!
Samwise
Samwise
you might want to hit me up i have a set of jaco blues that have barely any time on them of you would like to get them from me ide take a 20 for them. i think they had 3 batteries on them. previous car owner bought them used them 3 times then sold the car to me. i have not used them. they are in my pitbox. hit me up. im doug. ill be at the cc next sat. i sit at the far end of the gym.
pm me and i can text you a pic of them. you can still see the seam in the center of the tires.
Hi all,
Samwise
Samwise
RE FWD 1/10 TC weight
Hmm. Considering a 4WD SS car weighs 1450 grams minimum, we're talking about a 250 gram delta (amazing math skills, I know); slightly less than the weight of a standard-size lipo. That's a big difference!
Now I'm really thinking about trying an FF03 in Scale Spec!
Bill S.
Bill S.
interesting concepts huh. but could they be competitive? only fwd?
SRCR Novice
SRCR Stock TC
SRCR World GT
SRCR Scale Spec
SRCR Stock 1/12th
SRCR Novice
SRCR Stock TC
SRCR World GT
SRCR Scale Spec
SRCR Stock 1/12th
Bill S.
Bill S.
I want to see you do it!
