Team Magic G4
#9676
the material is harder longer wearing!
cheers
cheers
I bought some fly weights off this forum and on the header card on the packet it says "UFO clutch centrifugal shoe (red, harder)". What are they referring to when they say harder?? is it the material or do they help with a harder clutch engagement??? The weights are made by K-factory and the part number is K1497-11. Does anyone know???
#9677
ED pinions: Alum vs Steel
hi guys,
anyone tried the steel pinions? any reviews?
i believe the steel ones last much longer than the alum but at the expense of weight?
#9678
#9679
Be interested to see how much on both points though.
Regards,
British Menace
#9680
#9681
guys ... I am still chasing that K14145 WC upgrade kit ...
I contacted two of my shops but neither of them deals / wants to deal with the new TM distributor in Australia at this stage...
if anyone knows of an online shop that delivers overseas (to AU) and sells the part, can you please let me know ? ta
#9682
G4 worlds upgrade kit
Hey Omarko
Its a shame that you are having trouble tracking down a dealer to service your needs...
I have the kits in stock and ready to ship
If your local dealers wont look after you maybe try and contact RC garage in Bayswater VIC as they will ship anywhere in AUS. I would normally like to see a local dealer step up but if that is not the case then........
Talk to Adam
If you still have no luck then let me know
[email protected]
Talk to Adam
[email protected]
#9685
thanks! looking foward to getting it in.
one more question:
does anyone know if there is a single part number for a front differential.
I see the components for it, but i'm having trouble locating the whole assembly.
one more question:
#9686
Hi,
Is there a replacement pulley set for the Ed transmission? I got a G4Js on the way where i will swap parts on my g4s.
I'm just getting replacement parts and cannot find a direct pulley replacement set. I will order the front diff pulley, rear diff pulley and a pulley kit. Do you have to order one buy one?
#9687
Hi,
There is a small pulley kit in which you can get the ED transmission sized pulleys in plastic form (as per RS)
You do NOT get the rear diff' pulley, Brake pulley or front diff pulley. But I believe all others are included in the kit.
I just got a set. I'll try and find the part number and post later.
Regards,
British Menace
#9688
I would say,
www.rcshopping.com
will be one of the first to get them in. They ship internationally. But you'll find you'll be paying top dollar for the first ones out.
Regards,
British Menace
#9689
Hi,
Pulley kit: 502321 (27t,20t,20t)
Brake pully: 502323 (21t)
Front diff' pulley: 502318 (30t)
Alum' front diff pulley for spool and one way: K14122-9
With the pulley set, you need to have the 'S' or 'RS' two speed and front lay shaft's in order to be able to use them.
If you want a direct aluminium replacement for your "ED" pulleys. You will need to buy them seperately. Or buy the whole "ED transmission kit"
Hope this helps.
Regards,
British Menace
#9690
www.rcmanufactory.com
