Team Magic G4
#2177
The orange ones and the blue ones are silicon,there just a different color. I was not sure if the kits had them in them yet but I guess they do. I know the replacement shocks come with them.
The old ones were actually rubber and silicon oil makes rubber get hard. We recommended they change these in the spring. I'm glad it finally got done. We pushed them hard on the roll center adjustments in the spring to.TM is really working hard to refine this thing down to the Nth.
#2180
Originally Posted by wallyedmonds
lol like ntc3 and it dosnot work that good (and now the hate on me starts) use the proper tool a caliper to do your clutch.
#2181
Originally Posted by rcrevolution
so is my sway bar problem with the design? or something wrong with my car
Badda-boom, badda-bing, the arms now touch at the same time.
This should be done with the swaybar connected. This should also be done with the shocks disconnected. Refer to the owners manual for further info if you need pictures or something. It's all in there as to how to set this although they recommend setting it using both cams but then you're chasing a moving target so I found the 1 cam method works pretty well.
Cheers,
Mike.
#2183
Motorman:
Thanks for clearing that up
BB
#2185
#2186
Nice clip gansei !!!
The speedshot bulkhead looks sweet.
#2188
Originally Posted by gansei
#2189
ok when you say cam you mean those black little washers that turn and move the a-arm height correct?
and als which manual tells you how to adjust it? both the G4 and mongoose just tell you what it does and how to set it for the track, not how to adjust it
RcRevolution: Thats it, i think he is refering to the G4S manual. Maybe Team Magic have an online version on there website...
G4S has these cams on both sides of the sway bar as well, Mongoose is just one side
BB
#2190
BB
BB
anybody got it?
