Team Magic G4
#9151
guys ... what upgrades (in terms of parts) would you recommend for this car from the stock ?
cheers
cheers
#9154
what about the rear sway bar?? has any body tried the wire type of bar??? if so , wich one??
#9155
Yes. When the 'S' was only out a while. People/drivers noticed they couldn't get a stiff enough setting from the stock 'Blade' type sway bar ans started to use the Mugan 'wire' type sway bar.
It's reasonably easy to fit to. Just make a groove underneeth the rear cross brace. Drill two holes in the rear of the bottom wish bones and there you have it.
Using this 'wire' type bar. Darren Johnson for one (UK British Champ' with the G4 for 5 years in a row!!) had great success.
Hope this helps
Regards,
British Menace
P.S. Since the new top mounted Blade Bar has come out this has much more "Anti-roll" stiffness/ resistence then the stock blade found on the 'S'
Just a little harder, I think, to set up.
Hope this helps
Regards,
British Menace
#9156
The two screws on the rear of the carbon top plate. Which fix the top brace to the side brace stiffeners. The holes in the top deck need to be made over sized! Make them about a 4 to 5mm hole. Then put a washer beneath the screw you put in and don't tighten it down !!!!
It should just rest on top of the washer!!
This will allow the top plate and hence the rear "pod" of the car to flex and roll more and hence increase you grip
One thing though this does reduce the cars resistance to getting tweeked in a crash/ accident!! So watch the tweek on your chassis if you use this
Regards,
British Menace
#9158
helloooooooooooooo guys
i was thinking of buying this man~~
wonder is there's a gearing listing for it???
i tried couple of hour of search for site
..and still no luck of finding the list
be can here provide the gear listing available for this car ?? ? ? ?
really apperciate it if PM will do too thx man
oh yeah, happy be-lated easter day~
#9159
if its parts list and or option parts list, then go to
http://www.teammagic.com.tw/en/downf...=downlist&id=3
download the parts list for the car, and it has option parts also.
#9160
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
Hi guys......
I am going to be selling a large part of my 135 RC car collection, parts, engines, bodies, starter boxes, servos, kits, parts and accesories....My EBAY ID is therealfastharry...Great stuff is up there now......And I'm pricing everything cheap...Everything is in GREAT condition....
here's part of my collection......
http://www.rctech.net/forum/showthread.php?t=40662
thanks, harry......
thanks, harry......
#9161
http://www.kfactoryracing.com/produc...4122&pageNum=1
K14122 is the Part # for the whole tranny. If I remember right it comes with 16T/21T pinions stock. These are the middle range pinions. Part #'s for the additional pinions you add a dash & tooth #. Example: K14122-15 will get you the 15T pinion K14122-21 will get you the 21T pinion Etc. Hope this helps.
#9162
is anyone having problems with the first gear housing nut. from the factory they are pre assembled with a 51tooth gear and when I tried to get the nut off to change to a 52tooth gear it would not come off. and yes I know its a reverse thread. is this a defect????
#9163
Are you using the special tool or other tools? Just wondwering because I found it a little easier with the K Factory tool.
Does it look on straight?........maybe crossed threaded?
British Menace
#9164
I've noticed they do come really tight. I'm wondering if they locktight them at the factory??
British Menace
British Menace
