Team Magic G4
Old 08-10-2006, 03:24 AM
  #1651
Bundy_Bear's Avatar
Thanks guys appreciate the feedback.
NiMo: any probs with those screws i am talking about etc?
BB
Bundy_Bear is offline
Old 08-10-2006, 06:53 AM
  #1652
NiMo's Avatar
I did actually strip one when I built the car, the screw is still too tight to fall out though, my fault though, I put the wrong screw in the hole, but I have only ever driven the car with it like this and have had no ill effects, well if there are ill effect then the car could be awesome if I replace the part.
NiMo is offline
Old 08-10-2006, 01:42 PM
  #1653
charlesd's Avatar
Quick question on the g4. I own the mongoose and was wondering if i can drop in the s-class gears or do i need to buy a kit do to that? I wanted to put a 45 tooth second on my mongoose.
Charles.
charlesd is offline
Old 08-10-2006, 05:26 PM
  #1654
Car Breaker's Avatar
Charles.
I think the Mongoose come with S class gear
Car Breaker is offline
Old 08-11-2006, 02:40 AM
  #1655
Bundy_Bear's Avatar
Cool... On the old G4 it got to the stage were i couldn't hold a screw in there for a whole heat, was only one side though from memory.
BB
Old 08-14-2006, 11:11 AM
  #1656
Regional Moderator
Darkseid's Avatar
Alright guys, I somehow split my G4S rear dog bone. So I need a replacement. Where can I find one? Raceday Hobbies didn't have any listed in their ebay store. Does any other company dog bones fit in the rear, like Mugen or Kyosho something like that.
I just need to find a dogbone replacement before our next race in a couple weeks.
Thanks.
Darkseid is offline
Old 08-14-2006, 11:24 AM
  #1657
Go to his main site. or call them they do have them.
Motorman2 is offline
Old 08-14-2006, 11:26 AM
  #1658
yes mongoose is S class gearing as is The TM Evo version
S Class gears VS origional G4
Second spur gears are slightly smaller than the original G4, the second pinions are the same diameter.
First spur gears are the same as the original G4 and the first pinions are a different size (slightly bigger)
So if you go to S class second spur gears you should go to S class first gear pinions
Old 08-14-2006, 11:27 AM
  #1659
Regional Moderator
Darkseid's Avatar
Okay, I'll check there.
Darkseid is offline
Old 08-14-2006, 11:37 AM
  #1660
Regional Moderator
Darkseid's Avatar
Found 'em...
Wish I could say I found 'em cheap, but elas, it seems that while every other part on the G4S is reasonably priced, the universals AND dogbones aren't. $15.49 for a pair of dogbones.
Guess I gotta do what I gotta do...
Darkseid is offline
Old 08-14-2006, 12:06 PM
  #1661
NiMo's Avatar
RC Mart $9.00
Originally Posted by Darkseid
Found 'em...
NiMo is offline
Old 08-14-2006, 01:45 PM
  #1662
SCUBA STEVE's Avatar
Trader Rating: 89 (99%+)
Made a few changes....I just need a servo horn and my project is complete....I like this fuel tank alot better (ntc3) but it was a ton of work...I had to make a whole new upper deck and that was just half of everything I had to do!
Attached Thumbnails Team Magic G4-g4-proto-004.jpg   Team Magic G4-g4-proto-005.jpg   Team Magic G4-g4-proto-rsz.jpg
SCUBA STEVE is offline
Old 08-14-2006, 01:49 PM
  #1663
A few more... the pics did not come out that great.
Attached Thumbnails Team Magic G4-g4-proto-001.jpg   Team Magic G4-g4-proto-002.jpg   Team Magic G4-g4-proto-003.jpg
Old 08-14-2006, 07:00 PM
  #1664
Those are hella nice
I wish I can make it too, btw, where you plan to place the Rx. double side type on the side of throtal servo?
Old 08-14-2006, 07:34 PM
  #1665
boner's Avatar
Here is something I being testing have since March. You can see more at http://www.hodamotorsport.net/forums...hread.php?t=71
This hoda kit works on G4S or mongoose.
boner is offline
