Mugen MTX-3
Old 09-18-2003 | 03:09 PM
  #8056
Ah10's Avatar
Originally posted by loosenut
So that's a no go for those teflon bearings on ebay? Would you guys recommend then to stay with the Mugen stock bearings??.
G
Didnt say that! but I have good experiences with Dynamite Teflon seal bearings, they are strong and last a long time! but they are expensive too! $4 a pop on 10 x 15
Ah10 is offline
Old 09-18-2003 | 03:58 PM
  #8057
stefan's Avatar
Originally posted by tekrsq
That's what originally got me thinking about making one, but I haven't broken a shock mount yet, and don't have any spare/scrap graphite. I figured this one was basically what I need, so it's just as easy for me to buy it (as long as the price was reasonable). I'll have to keep looking for scrap graphite.
Tommy, fiberglass will do as well or even a piece of aluminum.
It's not really a high tech part and doesn't have to be made of space age materials
stefan is offline
Old 09-18-2003 | 05:43 PM
  #8058
Vinyard's Avatar
Originally posted by stefan
Would you really spent money, probably over $20 for this thing?
With a piece of scrap graphite and a dremel, it takes 5 minutes to make one and if you want that adjustable screw, go to you hardware store, get a threaded alu spacer and a nylon screw for a few pennies
I'm lazy..
Vinyard is offline
Old 09-18-2003 | 06:08 PM
  #8059
Manticore's Avatar
Default Re: Bearings
Originally posted by Roger
I've replaced the 10x15 bearings on my car with the stock mugen bearings. After awaile, these bearing will go. Just use the stockers and you'll be all set. Stick to the mugen stuff.
where is your mugen engine?
Manticore is offline
Old 09-18-2003 | 07:10 PM
  #8060
AMGRacer's Avatar
Hi Stefan. I know you mentioned that you are from Germany, wondering if you can translate what is printed on the 2nd page of this pdf.....................
http://www.reckward.de/download/VOR_OB_001.zip
I know it is for a Kyosho V1RR so manyby you will not want to do this
Would greatly appreciate this. Seems to be some sort of mod to the rear end.
AMGRacer is offline
Old 09-18-2003 | 07:26 PM
  #8061
stefan's Avatar
AMG,
they are grinding material off the rear hinge pin holder (bring it to 6mm thickness) and that other part, which I can't identify (it says: cut 1mm off to be able to lengthen wheelbase by 2mm).
The idea is to stretch the wheelbase by 2mm.
Hope this helps.
stefan is offline
Old 09-18-2003 | 07:28 PM
  #8062
AMGRacer's Avatar
AMG,
Hope this helps.
Thanks man appreciate it much.
AMGRacer is offline
Old 09-18-2003 | 11:29 PM
  #8063
Roger's Avatar
Default Re: Re: Bearings
Master Manticore: If you can believe it, I still run the Mugen MT-12 that has been modified with great success ( even though its not completely stock, its still a mugen )
Roger is offline
Old 09-19-2003 | 12:02 AM
  #8064
Manticore's Avatar
Default Re: Re: Re: Bearings
sorry Roger, I am not the master ! but we have a prof D here in this forum !
Old 09-19-2003 | 01:07 AM
  #8065
RClover's Avatar
Default Re: Re: fish is back!
Originally posted by EVOLUTION
Fish,i thought you drowned!!!
no, he was captured home by mermaid..
RClover is offline
Old 09-19-2003 | 03:25 AM
  #8066
fastharry™'s Avatar
From: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
I've had real ggod luck with the Duratrax bearings....They're teflon sealed also,and seemed to have less slop than the dynamite bearings.....
never broken one of them....they're expensive(in 10 x 15) also if you buy them by the pair....but you can buy sets for cars real cheap..
this is for the old HPI pro..and has 6 10 x15's (plus others) for 14.99........
http://www2.towerhobbies.com/cgi-bin...?&I=LXD054&P=7
fastharry™ is offline
Old 09-19-2003 | 05:54 AM
  #8067
bighurt98's Avatar
Solid Axle for MTX 3??
I am wanting to get a solid front axle for MTX 3. I'm having a hard time finding one since JustRC has discontinued thier solid axle. Any suggestions??
bighurt98
bighurt98 is offline
Old 09-19-2003 | 06:16 AM
  #8068
Thunder racer's Avatar
Y dont you just put/leave the oneway in it whats the diffrentce.
Breaks all four wheels thats the only diffrentce and you can get use to not having any breaks. I dont mind having no breaks in the front.
Thunder racer is offline
Old 09-19-2003 | 06:23 AM
  #8069
so with a one way the out side wheel can go faster on tha turn?? yes well this does not happen with a solid axle, so there IS more than one differance
Cartman is offline
Old 09-19-2003 | 11:07 AM
  #8070
Grinder's Avatar
Have ya guys had problems with the stock bearings?? I inspected my bearings in the front carriers the other day. THey were slightly stripped. The metal shields I guess...were coming off. That's no good if the bearing blows in a race.
I was thinking about replacing all the bearings with teflon shielded bearing set from this company called competition killer bearings?? http://cgi.ebay.com/ws/eBayISAPI.dll...category=19168
Anyone heard or used that brand??
Gary
The stock Mugen bearings are good, but when they wear out I suggest Acer ceramic bearings. I have had a set for almost a year and not one failure. If you don't want to spend that much they have cheaper bearings that are better than most out there.
http://acerracing.com/bearings.html
Grinder is offline
