Mugen MTX-3
Old 09-10-2003 | 10:12 PM
  #7906
Corse-R's Avatar
Originally posted by Fire
man i would love to play on a track that can pratically use breaks
the dump ass who sets up the track here make the lanes and coner so close and so narrow that i rely on momentum to get thru some S coners coz the clutch won't engage at such a slow speed
and unfortunately that's the only track i am able to go to play
Some few things that can you help on those tight tracks.
1. Narrow your car. Go to 194 or 195mm and the rear track 1mm narrower than front, this will help you rolling on the turns and be more agile through it.
2. Use higher roll center supports.
3. Probably you will be happy putting less caster (try with the 1mm shim at the front, rest of shims at rear) and more front camber.
4. Check with a thinner rear diff oil, something like 7000.
What do you use at front? diff or one-way?
About the problem of the clutch, probably you're using the Extra hard spring, try the stock one and set your clutch gap to 0.3mm or 0.4mm.
Corse-R is offline
Old 09-10-2003 | 10:16 PM
  #7907
Corse-R's Avatar
Default Re: Mugen Shocks
Originally posted by tIANcI
I need some assistance, after a good day out on the track my Mugen shocks are no longer damping well. If I remove the springs and compress the shocks, the piston will not fully extend. The reason I found is that the diaphram collapses a bit and is no longer the shape of a dome. Anyone has this problem and knows of a solution? Thanks.
Change the diaphragm for a new set of ones, as the shocks gets used it goes softer and the rebound is affected (and of course, be sure to eliminate all the air bubbles on your shocks )
Corse-R is offline
Old 09-10-2003 | 10:44 PM
  #7908
Fire's Avatar
Thanks for your tips man
got them copied down
btw i am using the oneway~
Fire is offline
Old 09-11-2003 | 03:42 AM
  #7909
smartdriver's Avatar
Default grub screws
3 mm grub screws are what I used and I will be putting two more 90 degrees from the first two to make it even stronger.
Thanks for the idea!
smartdriver is offline
Old 09-11-2003 | 04:18 AM
  #7910
stefan's Avatar
I'd say 180 degree if you want to spread the load evenly.
I still think that a hole in the outdrive and a screw that goes though would be best, but it would be harder to find it.
Maybe we could grow hair on the outdrive
stefan is offline
Old 09-11-2003 | 08:02 AM
  #7911
Default About those shock bladders....
Are there other ones besides the Mugen ones that will fit the Mugen shocks?? My LHS is fairly limited and no time to order online now.
Thanks, Kevin
hicheef is offline
Old 09-11-2003 | 08:08 AM
  #7912
Corse-R's Avatar
Default Re: About those shock bladders....
Borrow them from the MRX3 shocks (is what I do sometimes, are the same). Will be the best, but INRB, Yokomo ones fit on the shocks.
Corse-R is offline
Old 09-11-2003 | 08:17 AM
  #7913
i think to be honest your worrying too much, i don't run any rebound in mine
Cartman is offline
Old 09-11-2003 | 08:18 AM
  #7914
Default WOW
Didn't even think of that!!! Thanks Corse!!!
hicheef is offline
Old 09-11-2003 | 08:23 AM
  #7915
Manticore's Avatar
for those who care about their receiver packs !
time to show off new toy !!!
Manticore is offline
Old 09-11-2003 | 08:24 AM
  #7916
Manticore's Avatar
new toy again
  #7917
Manticore's Avatar
and again
Old 09-11-2003 | 08:26 AM
  #7918
Manticore's Avatar
new toy again !!!!
Old 09-11-2003 | 08:35 AM
  #7919
Manticore's Avatar
I wish this battery checker may last over 16 years !! too bad, i am not living in ireland !
Old 09-11-2003 | 08:36 AM
  #7920
FAST1's Avatar
Wink
OMG!!
Your receiver pack is low on voltage!!
FAST1 is offline
