Old 09-19-2003, 12:31 PM   #8071
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by Grinder
The stock Mugen bearings are good, but when they wear out I suggest Acer ceramic bearings. I have had a set for almost a year and not one failure. If you don't want to spend that much they have cheaper bearings that are better than most out there.
http://acerracing.com/bearings.html
they are great bearings.
Manticore is offline   Reply With Quote
Old 09-19-2003, 12:33 PM   #8072
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
I totally agree with Grinder. If that Acer Chick can be on it for years, so can the bearings...
eddiethefish is offline   Reply With Quote
Old 09-19-2003, 01:07 PM   #8073
Can u guys pls tell me the spring colors and rates that are made by mugen for mtx3 and also if u pls the associated springs too. I know theyve been asked many times but my computer crashed I had to reformat my hd erasing all my favorite rc webpages
many thnx
penggoy is offline   Reply With Quote
Old 09-19-2003, 04:32 PM   #8074
Send a message via Yahoo to hicheef
Default I know it's been asked but.......
Been searching for a while but I'm trying to dig up the complete parts list for a front diff in the MTX-3. Big track season is drawing to a close and I want to try the car for a bit with a diff up front. I have the halves but I need the parts list for the innerds. Thank you for your help!!!!!!
KEVIN
hicheef is offline   Reply With Quote
Old 09-19-2003, 05:02 PM   #8075
Kevin,
Call kevin at Ace in birlingam. He set me up and I built my solid front
Eddie
laorc is offline   Reply With Quote
Old 09-19-2003, 06:35 PM   #8076
Default ED P.
Whats Up Man!!! I owe you some pics from regionals!!! You think I shoould got to a solid rather than a diff??
Kev
Old 09-20-2003, 12:53 AM   #8077
is a same case you could use bevel gear for reg. diff. justrc and kawahara make adaptor for solid. Try both of them you might like them all. depend on the track and your driving style
Old 09-20-2003, 10:43 AM   #8078
Default you like that??
On a smaller track?? I might have to try that. Still want to build a real front diff though!!!!
Old 09-20-2003, 09:35 PM   #8079
rcmike's Avatar
Trader Rating: 40 (100%+)
PENGGOY- front purple 1.6,light blue 1.7,gray 1.8,white 1.9, rear springs are the same rate.. purple is the softest and white is the hardest" mugen does make a harder springs for the rear that is used on the mrx3. HICHEEF-do you have a fax??i can copy the instruction book and send to you if aval""
rcmike is offline   Reply With Quote
Old 09-20-2003, 09:48 PM   #8080
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
'Tis a sad day. The cold weather just reminded me I need to winterize my MTX-3.
Kinda wish I could race it one more time.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 09-21-2003, 02:19 AM   #8081
C'mon down to the sunshine CA.
Old 09-21-2003, 01:42 PM   #8082
Send a message via AIM to loosenut
Centax clutch problem!! Need Help.
I can't get my my clutch to engage. Basically when i gas the car, it doesn't go anywhere. I tried to loosen the springs but still same thing??? I ended up taking the the clutch assembly apart like 10 times adjusting that darn spring - nothing! I've loosen it to a point where I can use my hands and loosen it.
So I thought it was something else - like my flywheel not catching the SG shaft? Tried to take that off - ended up breaking my SG shaft!!! ARGH!!!! I had to buy a new engine cause I can't get parts for my sirio .12.
Anyways. Any tips or suggestions? I do have a few questions...
The thrust bearing?? There are two washers on each side of it right? Because on the manual it said that the thrust bearing is 1 piece and it doesn't refer to the washer on either side as a part number??
What might be the reason that I can't get the clutch to grab? Did I assemble the unit wrong? Also, do you guys know if the mtx3 kit came with a cone that goes on the engine where the flywheel sits? Or do you use the one that came with the engine?? I'm confused...I've got two cones - one smaller (black) one is larger and it's gold color....dont' know which one to use...
Unfortunately I got the car second hand w/o the engine. So I'm having to reassemble the clutch...any help would be appreciated!!!!! It's really frustrating!
GAry
Tekno SCT410//B44.x Avid Chasis//B5M//HW 3656 - 4700 kv// HW V10//MT-4
loosenut is offline   Reply With Quote
Old 09-21-2003, 07:36 PM   #8083
Roger's Avatar
gary: check your pm. Call me and I can help you with this. I'll check everything for you and make sure that everything is working properly.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 09-21-2003, 07:51 PM   #8084
RCTech Member #2
TSR6's Avatar
If I could afford to fly, both money and time wise, sure!
It's probably a good thing. I really need to do a full tear down before I run it again. I also have a speedtech order to make before it goes back on the track. I have one CVD & one Uni. in the front, kinda tore one off the last time it was on the track..heh...heh...
Troy
RCTech Member #2
Old 09-22-2003, 03:08 AM   #8085
Corse-R's Avatar
CVD ripped? That sounds me to 3Racing universals... Anyway, next weekend have a National Round in 1/8 (27/28) and 4/5 Nov the last in 200mm.
After this, unless I engage in some weekend run at mine local track, cars should be kept in dry until the next season and go to the indoor season (Pan cars in carpet rule ) starts to make cold, windy and probably damp conditions.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
