Mugen MTX-3
#7681
thanks thats what i figured.
#7682
thanks for the spring rates
this can be extremely helpful when going to a bumpy track with low traction.
#7683
Ok...I have got to emmit it!! Love the car!! I just got myself an MTX-3 for the 1st time! ....and yesterday...get to reace it ! 1st time with the MTX3 on the track!!...and wow...the car was nice !! at the beginning!! just some tweeking it will be awsome!! I have the Impulse and 705 and I have to say! This Mugen is a littler easier car to work on. Some how..with my 705 I alwasy have the problem with the car. Nat that it's a bad..car...but..you sure have to put alot of work into it to make it work great! withc ...I did... and it work out fo rme nicely!...But...still a little glitch to fix...any ways.... out the the MTX3 and end un in 2nd in 30Min A main! I was very happy with the car! Tho..during the qualify .. I do have some problems.
I use the fron one way at 1st....and the front CVDs. I samp 2 and bend 1 of my CVD....all in the same side....(Right side) I didn't hit any thing that hard at all!! and that serprise the hack out of me?? Wonder how I did that?? But..some how I manage to drive 3wheels(with the front oneway) and get me in the A main. So...after 2 brocken CVDs (luckey me I have an extra set) and a bent one.... I decided to built the front diff ( Witch luckey...I have most the parts for it) I it was very stiff....I used my buddy HPI diff greese and the motor shim for hte gear shim...and it seem to work ok. ..after 30min of the race! all my CVD is in tack. Not a problem... So..the questions is...was it the oneway with the new MT12 that samp my CVD?? or was it just the CVD that is not so strong?? (3Raceing CVD).... any suggestions?
#7684
Ow...and I forgot to mension...I think...I might have convince..3 racer to leave their royal brand and get the MTX3!! LOL...
They like what I drive! and they like the price on the parts!
Oh..and here is the web site for my local racetrack.
www.wnyrcinfo.com
www.wnyrcinfo.com
#7685
Re: Clutch adjustment
Originally posted by EnzoFerrari
I got my car running and im having a problem with my clutch setup. It's taking alot of rpm to engage. how do i adjust it to make it engage earlier? Is it by loosing up the collar that holds the spring? Or by removing washers in the front of the clutch?
#7686
I seem be having problems with my clutch. im not sure if it's something to do with my brakes or what. I made the screw real loose and i'll try it in a few minutes. My car rev's very high before it goes anywhere. My clutch endplay is set to about .4mm.
#7687
#7688
#7689
what would happen if the spring adjustment was too loose?
i tried it and my car is much worse. I will try tighten it all the way and one turn out and see what happens.
#7690
hey i have a used mtx3 for sale w/ rossi pixi outlaw engine. Spare chassis, aluminum a-arms(only front upper installed) green/red turnbuckle links, and 3 racing hop ups. Will come with 4 bodies. Anyone interested?
#7691
ok ill have it $50 posted
#7692
Originally posted by FREAKAH
In Hawaii!
And look around................not a single grass shack to be found.
In Hawaii!
#7693
cartman- are u refering to my car?
#7694
second the clutch wont engage till like half throttle since it is so tight! you might want to set it up to where the point when you blimp it, it doesnt engage
#7695
