Mugen MTX-3
#6931
I run Speedminds with the 1 mm aluminum washer from the MTX2 prospec.
#6932
Jose
#6933
Originally posted by B
i recently bought a new pair of speedmind 30mm 37Shore Rear tires for the mtx-3
the problem is, they dont fit !
I am confused, the original stock tires (rear) have how much offset??
does the front stock tires have offset as well?
Now, how do i solve my problem? Will getting the kawahara alloy wheel hex with the 1mm spacers help (is the 1mm shim enough..?)
All i know is, with + offset, the tires will be pushed further out...so from my guess, the original mtx-3 stock rear tires have negative offset??
and why doesnt any of the foam tires put the amount of offset on their packages, is it because they are all the same? ( i do now know the offset of my speedmind tires, because it is not on the package box)
i know these are a lot of questions, but i am kinda stuck here, thx for any inputs
I have tried the Speedminds 0mm offset and they work fine and am running without any spacers.
Alternatively you may want to add in the 1mm spacers.
#6934
ok
i gues my question comes down to this
Can the mtx-3 use all kinds of offset tires in the rear? (as in can all FIT)
and...
what kind of offset tires are offered by GRP (Ellegi, Power Tyres in particular)
and....
the shims are to be used to adjust the offset right? (e.g, use 0mm offset tires, put one 1mm shim --> 1 offset)?
thanks
and...
and....
thanks
#6935
Does anyone know who has the 48 pitch gears in stock(including the 20T pinion)
#6936
ok
and...
and....
thanks
ok
and...
and....
thanks
I have tried Jacos, Speedminds and GRPs.. all work fine.
All are 0mm offsets.
If you like the tyres that came with the kit, you can try Mugen's Fast tyres. they are 2mm offset..
Otherwise yes you can run those 0mm tyres with the 1mm spacers.
#6937
esham, howz ur mtx-3 conversion coming along....??? keep us updated....k?
#6939
I run the 1mm spacer if Im not using the fast tires
#6940
Light weight 2 speed shaft in stock!!!
JustRC
JustRC
#6941
Vinyard
Thanks a lot man!
Vinyard
Thanks a lot man!
#6943
I am looking for the lite weight shaft will you be coming to revelations I will be there on wed around 1pm
#6944
Eric: Describe you and your car and your pit area please...
JustRC
JustRC
#6945
blue shirt blue shorts white body with orange fantom racing stickers.
