Mugen MTX-3
#6946
Re: Mugen fast tire shore advice
Originally posted by US_MATRIX
Hi,
I am planning to get some Mugen fast tire and i live in Bay Area, CA. I was just wondering that what shore (37,40,42,45) you are using for High and Low traction? Is it always use harder shore in front than rear?
Thanks.
Hi,
Thanks.
#6947
I run my car with the spacer all the time regardless of the choice of tire brands, which range from Kawahara to Ellegi, FastTire. As long as it doesn't rub against the knuckle, that's the only thing I care about.
#6948
Shock Oil
Anyone know the Mugen Shock Oil #600 is equivalent to Trinity what shock oil Number? Or does it the same as Serpent Shock Oil #30?
Btw, do you guys use 2 piston holes or 1 piston hole for the front shock or what shock #, assuming you are running on less traction packing lot race?
#6949
Re: Shock Oil
#6950
Re: Shock Oil
http://www.twf8.ws/new/tech/tip/shock.html
Based on this the mugen oil is just under 50wt.
#6951
possible dumb gearing question
Ok, this may be a stupid question but If I am going to change the gearing do I need to nake sure there is a 4 tooth difference between the pinions and spurs on both 1st and second gear like the stock ones are to maintain proper mesh? for example if I put the 15th 1st gear pinion on do I also need to change the second gear pinion to the 19th or can I leave the 20th and so on.
Troy
Troy
#6952
Originally posted by justrc
Light weight 2 speed shaft in stock!!!
JustRC
JustRC
#6953
Re: possible dumb gearing question
Troy
Troy
Best to go with is the 0.8M gear modules from Mugen (if you run a MTX-3), this set of new gearing allows you to run a wider tooth spread without having to worry about..
#6954
Re: Re: possible dumb gearing question
Thanks, my new NS12 S3 seems to have plenty of torq so thats good news. 15th to get it out of the hole and 20th for good top end. Cool
Originally posted by RClover
troy, from 15T jump to 20T could still be possible if your engine is torquey enough to pull away when 2nd gear kick in! You need to re-adjust your 2-speed clutch to suit your powerband to avoid a sluggish 2nd gear which will cost you lots of time.
#6955
Re: Re: Re: possible dumb gearing question
#6956
Someone out there still owes me a full report on the followings:
0.8 gear system
Ceramic bearing
I wouldn't have bothered you if I am not concentrating on learning the WD40 Tunning effects.
0.8 gear system
Ceramic bearing
#6957
0.8 gear system
Ceramic bearing
0.8 gear system
Ceramic bearing
WD40
KY
while you are learning them !
#6958
Originally posted by Manticore
how about a trade off for the following reports :-
WD40
KY
WD40
KY
#6959
Roughness is what the lady prefers most...
#6960
Just wanted to post my MTX-3's new racing skin I know it's not a very creative paintjob...but I like to keep things simple
Anyone know how Protoform BMW bodies run???
-Puma
-Puma
