Mugen MTX-4
#3721
do i have to get 2mm offset wheels(foams)? fast tires
#3723
Originally Posted by sook
It really does not have anything to do with tight gear mesh or a one piece engine mount. Although the one piece engine mount is sweet. It was actually mentioned early on in this thread, but it is a very good truthful fact. Your engine must be near perfect to perpendicular to the gears. Keep the split between 4, 5 or 6 and it should be fine. Anything more and you are taking risk at losing the second gear. If your engine alignment is near perpendicular line to the gears without any odd angles, you will not have a striping problem.
Well this past State race, at Kissimmee Raceway, Kissimmee FL, 6 MTX4's, including mine, blew 2nd gear. Now I'm not new at this, and I think I might have blown 2nd gear in my MTX3, once in 2 years. Now I've gone threw 7 2nd gears now. Not sure what's going on, but I'm getting pretty tired of working all weekend to get the car dialed in, for 2nd gear to give up like it did, again.
2 cars that lost 2nd gear, were Mugen team drivers, that I won't mention names. 2 Other cars, are people in the top of the list for our division.
With us racing in Serpents back yard (Florida) you would think that the TEAM Mugen, would help all the none factory backed Mugens, at a State, or National event. Not so.
#3725
#3727
what shore foams are being used for the MTX4?
#3728
#3729
#3730
Originally Posted by Riketsu
I was running the clutchbell with only two bearings... This is what happens when you buy an used car . But I got such a good deal on it its alright... . I'll report after this upcoming weekend all of my mods/checks to see if they resolved stripping gears. Top drivers like Art Carbonell, Gianni Giorgio and other serpent drivers are going to be visiting the island; hopefully I'll give em a hard time with my stock TZ Mugen (probably not).
#3731
a friend of mine lost 3 60t gears with no reason the same day, he switched from 17/23 53/60 to 17/23 53/59. and the most important thing, he added more space between the shoes, two months with the same spurs so far, just had to re adjust the screw for the shoes
#3733
To all you guys blowing gears, I wish I was there when it happens so I could see what is going on. I have put about 3-4 gallons of fuel through my MTX4 (got mine out of the first US batch) so far and have not stripped a gear yet. I did lose some on my MTX 3 in 2 years, but that was usually from the car catching air. If you think it is happening because of hard shifting, tighten the center screws in the 2 speed shoes. I run those with a reasonable amount of space between the shoes. This will smooth out the shifting. Other than that, without being there I could only speculate on what is causing the problem. Like I said, I have mine almost as long as anybody and haven't trashed one spur gear yet.
#3734
my 1st round mugen qlfying set up.
Won the 1st round with tough fight among RRR.
track width
F 198.5mm
R 200mm
camber
f L 1.5 R 2.0
r L 2.5 R 3.0
Toe F +1 R -2.5
Upper arm post 0.5mm
Shock piston F 1.1 2 holes R 1.2 1 hole
Shock oil F&R 500 mugen
Shock spring F light blue R grey
Shock post F 2,R from top 3.
steering ackerman C
Lower arm post Centre
Upright spacer 1mm
Antiroll 2.1mm 0mm
Upper arm post middle
F 1way rear 15K diff.
Side pulley 24t
Clutch shoe grey,spring medium
Centrifugal light weight 4pcs
Bell clearance 4mm,spring nut position 1.2mm(direct bearing no washer)
Gear pinion 17/22 spur 59/52
Tyre F37 62.5mm R40 64.5mm
Run time 30mnts.
MUGEN POWER!!
track width
F 198.5mm
R 200mm
camber
f L 1.5 R 2.0
r L 2.5 R 3.0
Toe F +1 R -2.5
steering ackerman C
Upright spacer 1mm
Antiroll 2.1mm 0mm
Side pulley 24t
Run time 30mnts.
MUGEN POWER!!
#3735
Originally Posted by Scott Fisher
What help are you looking for.
