Old 03-05-2006, 06:15 PM   #3706
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
Mine only came with 2 that I know of. I have extras because I was going through them a while back.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 03-05-2006, 06:20 PM   #3707
Send a message via ICQ to Lassis
my mtx-4
Mugen MTX-4-imagem-013.jpg   Mugen MTX-4-imagem-022.jpg   Mugen MTX-4-imagem-018.jpg
Luciano Assis
Virtual RC Racing
- Champion World Series 1:10 Sedan 2008 and 2009
- Champion Winternats and Spring Series 2008 1:10 Sedan
- World Champion 1:10 Sedan 2007 and Winter Series 2007 1:10
Lassis is offline   Reply With Quote
Old 03-05-2006, 06:25 PM   #3708
Lassis, how do you like the Stratus 3.1 body? I like it quite a bit. Way better than the Mazda 6.
Joe Cude
Old 03-05-2006, 06:28 PM   #3709
ogreasurada's Avatar
Originally Posted by GrandeGixxer
Mine only came with 2 that I know of. I ahve extras because I was going through them a while back.
That's strange, cuz mine came with 3....but mine was one of those from the first batch.
ogreasurada is offline   Reply With Quote
Old 03-05-2006, 06:36 PM   #3710
Mine was from the first batch too. It was a Hong Kong kit though. Maybe that makes a difference.
Joe Cude
Old 03-05-2006, 07:10 PM   #3711
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Originally Posted by Lassis
my mtx-4
I'll be praying for ya so that your car doesnt get any rash from the engine. j/k...
Riketsu is offline   Reply With Quote
Old 03-05-2006, 07:27 PM   #3712
What is the size of the holes in the stock damper pistons?
JPFX is offline   Reply With Quote
Old 03-05-2006, 07:57 PM   #3713
I hear that guys are saying that the clutch bell is hitting the second gear. Looking at mine it has 3mm clearance between the two of them. How much clearance does yours have? The clutch is closer to the second speed clutch bell but not the gear it self.
THE DOCTOR is offline   Reply With Quote
Old 03-05-2006, 08:32 PM   #3714
Thumbs up
When I built my car, the sway bar was rubbing ontop of the 2 speed housing. It would only happen when all the weight was up front or when the rear tires were in the air from picking my car up. But I took care of that problem back then and I was still striping 2nd. i'm just glade that I don't have to deal with it anymore. Now I can concentrate on my driving without worrying if my gears are going to go. I think the 1 piece engine mount helped sum. I also think using a good tool helped a lot including a real tight gear mesh.
mgreen is offline   Reply With Quote
Old 03-05-2006, 08:54 PM   #3715
Roger's Avatar
The reason why the rear swaybar is rubbing against the 2 speed housing is because your droop (rebound stop) is not adjusted. Mine did the same thing and when I set my rebound stop to 5.0mm (stock reccomended set-up), it cleared with no problems.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 03-05-2006, 09:29 PM   #3716
Trader Rating: 35 (97%+)
Send a message via AIM to King of B Main
got to give props to mugen and to jose cases for winning the pre-nats at crystal park. The car looks great. I think half of the a main were running mugens.
King of B Main is offline   Reply With Quote
Old 03-05-2006, 09:42 PM   #3717
People should been used to that kind of scene for a while now..
Old 03-05-2006, 11:01 PM   #3718
asw7576's Avatar
Originally Posted by Isaac
Ok before I even start building my MTX4 I need to know if this 2nd gear stripping is something I should be really concerned about. If is there a fix for it? Please feel free your suggestions. My car is still in the box with plastic wrap still in place.
You can buy alluminium upper engine brace ( the bar that connects rear bulkhead to radio plate tower ) and one piece engine mounting by 3racing.
Some early version kit might have problem with front bulkhead not matching the contour of chassis ( need filing on lower hinge pin area at the 90 degree section ). You need to try first, if you can't screw properly then you must stop. You need to to see the hole and determined where to file.
I suggest to replace all sort of 3x8mm screws with 3x10mm screws and 3x10mm screws with 3x12mm screws. Longer screws make your car stiffer, stronger, and heavier ( but your car will be at ROAR minimum legal weight ).
Old 03-06-2006, 04:43 AM   #3719
GrandeGixxer,
I liked it very stratus 3.1
Luciano Assis
Virtual RC Racing
Old 03-06-2006, 07:23 AM   #3720
It really does not have anything to do with tight gear mesh or a one piece engine mount. Although the one piece engine mount is sweet. It was actually mentioned early on in this thread, but it is a very good truthful fact. Your engine must be near perfect to perpendicular to the gears. Keep the split between 4, 5 or 6 and it should be fine. Anything more and you are taking risk at losing the second gear. If your engine alignment is near perpendicular line to the gears without any odd angles, you will not have a striping problem.
sook is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
