V-ONE S Thread
#3421
Originally posted by Sp Racer
Kyosho make one,pretty expensive
unless you're gonna race on foam then forget it!
LS
LS
I have been thinking ill get one on and off for a while, I usually run on foams, why are they no good for rubber?
#3423
The one way on a rubber car basically makes the brakes useless
#3424
when do the new kyosho v one s come out in the US?
#3425
hmm
i think i will still get the one way
even tho i dont run foams
#3426
Does anyone know if the Thunder Tiger starter box will work with the V-OneS and GS15r?
some guy at the club reckons it wouldnt
#3427
My starter box is the Thunder Tiger Stainless type and I can assure you it works. There may be another version available just make sure it has both inline and transverse mounting positions for the starter wheel.
gt
gt
#3428
http://www.acehobby.com/acehobby/pro...ar/starterbox/
is this the one?
and you dont need a new flywheel do you?
is this the one?
#3429
no its not the same, mine has stickers all over it and some scratches! .....yeah thats the one
gt
gt
#3430
nice stickers!
apparently with the stock flywheel it misses out on hitting the wheel by 2 or 3 mm did urs do the same?
#3431
I cant understand that!.....allthough the FD 49 Flywheel is still std diameter so it shouldnt make a difference........no wait....heres proof, the photo is an S chassis and shows how far the wheel can protrude without fouling on the chassis. It will work!
gt
gt
#3432
Ok thanks, I can get one near new for like $60 I think. After using a starterbox on the w/e I never wann ahave to use that dam pull starter again
Better work or your in trouble
#3433
Hmmm....Unless you've changed the motor, then a VoneS with a 2 speed and GS15R can run in "pro stock" using rubber tyres (a great class BTW) ....that's the class I mostly run
Watch out at the next VORTEC Mr. Sola..... Schuey's comin' atcha !
But seriously, with that setup on your site my car was SOOOOO easy to drive.... and fast too! For once I wasn't battling it and BOY DID IT SHOW !
#3435
Originally posted by V-One S Racer
Damn straight it's a great class !
Excuse that, just an un-necessarily inflated ego from the last race meeting !
If I can sort out my engine problems ill be comming fo rall of ya
