V-ONE S Thread
#3271
wat about in da US? cause this one shop told me to find a price to match
#3272
Originally posted by sausage_link
wat bout your S for sale squizzy?
dave i was thinking bout your idea
how are you making the sensor.... i was thinking that you might use probes... but then i thought is it wise to send a current thru nitro?
and with the fuel sloshing around how will u get a accurate read out?
Have a look!........oh well guess ill lose out a bit
gt
#3273
Do u have a reserve at all on the car?
or as soon as the time is up its gone?
#3274
how come most of v one s ppl are from australia? hehe
#3275
The current/voltage on the probes will not be big enough to cause any problems. but the current is not what ignites fuel its the spark.
the gauge is just to be used as a guide, not a measuring device. when the level gets down close to the tip of the probe it will yes, it will be inconsistent but you know its close to the bottom and the more the light comes on the closer to the bottom it is.
The only other way is to use a flow meter but i havent seen anything that small to fit on a rc car.
#3276
memory has just kicked in...
Places along rivers used to use special wierdo gauges.
They were just like a small floating device in a tube.
the top was open, but only enough to let air in and out, not the floating device.
no the tube goes to the bottom.
the floating device is only just big enough to fit inside the tube.
and this way, it removes most of the sloshing and gives a fairly accurate reading.
this is what they used to use at some places along rivers to get tide height, (Like on river thames) and the waves dont give an innacurate reading.
#3277
sounds like wat they use in real car fuel tanks
#3278
Originally posted by squizzytaylor
Here!
gt
Here!
gt
#3279
Originally posted by esham
squizzytaylor, I did refer to the attachment. What really the cheat means on "loose" during entering and exiting stated in the attach. Can you explain.. Thank you. It regarding the droop attachment. Where the statement Scenario A: A car is too loose while entering a corner.
lose===rear of car spin out
#3280
#3281
i drove my car for the first time in like a month
went good
#3282
It probably is the same design actually wat i explained as what they use in real cars.
I dont think it would b easy tho to get a small enough one made to do it.
#3283
Man this thread is dead !
#3284
#3285
well I cant say anything anymore.......I sold my last v-one-s and now I only have a V-one-rr and A schumacher fireblade evo.
gt
gt
