V-ONE S Thread
#3571
Re: tyres
Originally posted by VoneS II
because I usually do carpark racing i was using semi-slicks but i ask i guy at the track and he said foamies are fine because they clean the track. and i wasn't referring to rubber as being crap i ment that if i wana do some burnouts i buy some cheap rubber. i realise that it came across wrong after posting it.
Ryan
Ryan
Foams are so much easier... no gluing and choosing inserts and stuff like that .
#3572
help
help
I started my car 2day and when it idling the whells are still spinning.i have tried changing the idle put it still does it.i think my clutch it gone but not sure.
PLEASE HELP
Ryan
PLEASE HELP
Ryan
#3573
I'm getting my V1S tomorrow..i have a Side exhaust threaded crank engine with me now.i plan to drop it instead of the stock engine.
would i need special engine mounts?
Ryan:
if ur wheels are spining too much at idle,adjust the mixture(Low speed) needle.richen it a little.
Ryan:
#3574
I have tried this, i tried rich then lean both low and high end. i called the hobby shop and they think its the clutch shoes, im taking it in 2morrow
Ryan
Ryan
#3576
Ryan
Ryan
I would recommend buying the um210 clutch!
Hope this helps
#3577
Ryan:
Ryan:
#3579
Umm...
pillow balls ? ive broken 1
glow plugs ?
These cars are pretty tuff
You decide
Ask v-one s racer
glow plugs ?
You decide
Ask v-one s racer
#3580
clutch
i took the clutch apart and it look fine so i took it to the hobby shop and my mate there is going to fix it for FREE!!!!!!!
Ryan:
Ryan:
#3581
It wont be your clutch !
Its most likely be your linkages or mixtures
#3582
I took my car to the hobby shop they fix it while i so there but when i got home it still spins the wheels and now it accel. all by itself ,the weild thing is when it accels by itself the throttle doesnt open anymore than it would at idle.
HELP
Ryan
HELP
Ryan
#3584
HELP
Ryan
HELP
Ryan
All I can think of is the idle speed, low end mixture or a leak in the carby.
#3585
Thanks sausage_link
should've asked earlier..but
what spares should i get?
i live pretty far away from the Kyosho dealer...and this is my 1st time with kyosho.
Thanks sausage_link
I'd suggest:
- Pillow balls (I've bent a few, but I whacked them back into shape with a hammer)
- Drive belts definately!
- A pulley set
- Dogbones (they can pop out, happened to me and driving with it like that is not easy )
- Suspension arms (to be safe... )
That's about all I can think of at the moment... anyone else got anything to add...?
