Kyosho v-one rrr
#9631
Location: Cebu City, Philippines and Ocala, Florida, USA
Hmm...the supplier of my kit was selling an RRR standard kit with the Evo upgrade package... I think he got his supplies directly from Japan. What my friend got from this package was 2 carbon fiber deck (the RRR deck and the RRR Evo dec), the sets of shock bodies (the RRR shock bodies and the RRR Evo shock bodies), 2 sets of spur gears (the RRR spur gears and the hardened spur gears), and all the Evo upgrades...
#9632
set up
Hi guys!can anyone tell me a set up for low traction surface?tyres,fluids,ride height,etc.i have a rrr wc with sp chassis,gold shock shafts,hollow front and titanium rear shaft.this car is really oversteering
#9633
Try lowering your roll center to the lowest position in the rear...take the rear Hinge pins and slide then into the inserts that allow the pins to sit at lowest postion this should help alot also try softening up the car ...500 weight oils for shocks, black springs all the way around soft settings on sway bars, 2.5 toe in rear, 1 out in front, front 2.5 camber , rear 4.0 camber, 35 tires or 37 front and rear, 10000 diff...ride height and tire size depend on track,size surface smooth and or bumpy, example if smooth and 1500-200ft straight use for quals experiencing 1mm wear every 8 minuts 59mm rear 57 front height front 5mm rear at 6mm all else use stock settings...hope this helps
#9634
Kawahara Brake Disk
I have just put in the kawahara brake disk and had to increase the width between the stock pads to 8mm because its twice as thick as the stock disk brake, which meant screwing out the 15mm screws a fair bit.
My concern is that the screws may be out too far even though the disk pads seem to be sturdy.
Has anyone has any problems with the kawahara brake disk and stock pads falling out during racing?
Should I use longer screws?
Thanks.
Thanks.
#9638
drive: one way
shocks: oil: 60 wt. (black diaphram / bladder #W6006)
shock position: 2.5 (middle hole)
springs: stock (black/medium)
servo saver: #10
roll center: high (hinge pin in lowest postion)
caster: both spacers behind arm (2mm / 8.5 deg. angle)
toe: 1 deg. out
droop: 0 (using droop blocks and gauge)
track width: 198 mm
camber: -2
anti-roll bar: 60 deg. angle
ride height: 5 mm
tire shore: 40
tire diameter: 58 mm
Clutch: stock / adj. nut: 0.8mm
Gearing: 17/ 61 1st gear , 23 / 55 2nd gear
Rear:
drive: 20,000 wt. diff oil (increase thickness to help car rotate more)
shock oil: 60 wt. (black diaphram / bladder #W6006)
Shock position: 3
springs: stock (gold/hard)
roll center: medium low (next to lowest position)
upper arm height: 2 mm
toe: 2 deg. in
droop: 2 (using droop blocks and gauge)
track width: 200 mm
camber: -3
Anti-roll bar: 2.0 / adjustable blade: 60 deg.
ride height: 5.5 mm
tire shore: 40
tire diameter: 60 mm
#9639
What are the advantages of using a 24 tooth front pulley. I know you can use the same diameter tires, but does it improve the car handling? The stock belt is too short, and the recommended one is a bit loose unless you turn the belt tensioner around. Doing this both sides of the belt almost touch.
I see the main advantage being that I will now be able to use all of my small rear tires.
Thanks in advance
Thanks in advance
#9640
my set up
front spool
rear diff fluid 60k
shock oil is 30wt fr & rear
black springs every where
40 shore 56-58mm
40-42 shore 58-60mm rear
OS TZ .12 with rd logics pipe
4.5mm front 5.0mm rear ride hight
PS I found that the smaller diameter the tires the more traction I get, some times way toooooooooo my like when I ran ~54mm & 56mm rear the car flipped sideways it was great.
rear diff fluid 60k
40 shore 56-58mm
#9641
front spool
rear diff fluid 60k
40 shore 56-58mm
rear diff fluid 60k
40 shore 56-58mm
#9642
Thanks in advance
Thanks in advance
#9643
Thank you Kewdawg, at least I know that I haven't assembled it wrong. The only reason I have put this on is so I can use my small rears. I was also wondering if there was going to be a downside in the car handling?
#9645
Is the RD Logics chassis any good? I bent mine in a big crash, and the local hobby shop doesn't have a replacement. I got on of the RD Logics aftermarket chassis and have fitted everything onto it.
Does it change the handling? The one I have iss 3.5mm thick.
Thank you in advance
