Kyosho v-one rrr
#8881
Location: Cebu City, Philippines and Ocala, Florida, USA
Originally Posted by maskedrider
i had seen the 3racing lightwight flywheel..
is there any good one out there beside 3racing ?
Kyosho only have the clutch bell only, am i right ?
thanks
thanks
#8883
great..thanks
#8884
Originally Posted by rmdhawaii
About the only thing I spied that I didn't see before was the Lightweight 1st Gear Housing. That looks like something I might have to get.
http://www.shopkyosho.com/img/produ.../410/VZW064.jpg
#8885
Originally Posted by doki_doki
Hmm...the link that you posted showed a picture similar to the lightweight first gear housing that came with the V-One RRR WCE. I might be wrong though. Have to check the part number first...
#8886
thanks
thanks
standard part of Evo WCE
http://www.shopkyosho.com/product/pr...YOVSW043/410.0
http://rc-mushroom.com/product_info....ducts_id=10951
#8887
Originally Posted by RoNTC3
RPM makes a thing called the bearing blaster. Use elecrtic motor spray and it works great. For lube I use Trinity royal oil.
I bought oil for slot car bearing.. it's called Mura
strange, but now the bearing is much more free, i mean it run easier.. but not smooth as grease.. and it's possible hear a small noise when i spin the bearing
did I make anything wrong?
#8888
thanks
thanks
#8889
Originally Posted by empty
The Kyosho lightweight 3D flywheel is VSW-043. lightweight clutchbell is VZW-213, which is fairly easy to damage when changing pinion gears.
#8890
Originally Posted by robert maestrey
Hey fellas thought you might enjoy some of theses pics from W-Nats...
Check out Chef Toso..ultra cool
http://www.nitrokb.com/profiles/Robe...rey2007WN.html
Robert,
Great pics! Glad things went well!
#8891
Originally Posted by picco007
Robert,
Thanks the Jl picco Murnan was running with a touch of RRR
#8892
strange problem
So last week I got my second chassis ..but I did not buy a new one ...I got a second hand one from a racer at my club. I could not ignore the deal because for the price of one new rolling chassis, I got one built up car with a Novarossi N12LL5 motor and an unbuilt car (minus a couple of parts). I was able to build a 90% new car, use the Novarossi engine, buy new servos and still have enough parts left over to serve as spares for a very long time ...I think it was a good deal.
The one thing I did not rebuild on the car was the engine, clutch assembly and the 2-speed assembly. When I got to the track on Saturday to test the car, I found a major problem. Basically the engine revs and responds just fine until you get to around half throttle ...at which point the engine responds but the car does not move! It's almost as if the pinion and spur gear lose contact somehow ...which surely is not possible. Could it have to do with the 2-speed assembly? Maybe my second gear? ANY help will be appreciated ....thanks!
#8893
I got a question...
Can i upgrade a V1-RRR to V1-RRR Evo using the EVO Conversion kit?
Or is the conversion kit for the V1-RRR WCTE?
Thanks.
Thanks.
#8894
The conversion kit will convert a RRR to a RRR Evo. Unfortunately, the kit is no longer available.
#8895
I FINALLY got my kit !!! 1 Question, what is the secret to getting the pivot ball covers in without cross-threading them??
