Kyosho v-one rrr >
Kyosho v-one rrr
Kyosho v-one rrr
Old 02-28-2007, 01:44 PM
  #8896
rmdhawaii's Avatar
Originally Posted by RoNTC3
I FINALLY got my kit !!! 1 Question, what is the secret to getting the pivot ball covers in without cross-threading them??
This can definitely be a problem if you haven't done it before.
First, take your time and turn very slowly. Once you have some bite, make sure it's straight before continuing, as that's where most of the problems start. Once it's in straight, turn 1/8th to 1/4th turn at a time and check to make sure it's still straight each time - if not, back it out and try again. If it's good, continue going until it's fully seated. When you turn - and I know this sounds somewhat difficult to do, try to make sure that the allen wrench (assuming you're using the kit one) is perpendicular and that you're not angling it some how - which can also cause it to go in crooked.
It may take some practice before you can do it without stripping the plastic, but keep at it. Try the back ones first, as the left and right one are interchangeable if you strip one and have to buy another set. The fronts are not interchangeable.
Hope this helps.
rmdhawaii is offline
Old 03-01-2007, 12:11 AM
  #8897
A
A's Avatar
Although i have made the servo horn 18mm as the manual states, it hits the fuel tank. I realise there is a short throw on the steering but is this the way its supposed to be? requiring adjustment of your transmitter to avoid binding?
A is offline
Old 03-01-2007, 01:12 AM
  #8898
rmdhawaii's Avatar
You should not have a problem once it's mounted in the car and you've adjusted the steering throw. If you do, let us know.
Old 03-01-2007, 09:05 AM
  #8899
jeff1's Avatar
I recommend drill the top of horn.. (let properly space for ball link) in RRR manual says to take a little of material off I'm not sure on Evo.. You can also screw the fuel tank more to the rear (it can help a little) the final adjustment is done with everything read to go. In the back of Setup-Sheet you will find how to set neutral and 100% turn left right looking to top of servo saver ball link screw and radio plate
jeff1 is offline
Old 03-02-2007, 05:11 AM
  #8900
maskedrider's Avatar
how to tell my Diff gear are going to worn out ??
I'm been using it for a year plus now and to me, it's still look alright. Or should i change to a new set as since its a year old plus ?
ps: it's not that expensive parts in the List
maskedrider is offline
Old 03-02-2007, 05:28 AM
  #8901
jag
jag's Avatar
It's helpful to have the right tool. I find it much easier if I use my Hudy 4mm (or whatever size it is) driver or glow plug "T" wrench. The cap will only go on the wrench so far and then it will sit flat. Then I can push it while turning and it goes on much easier. Does this make sense?
jag is offline
Old 03-03-2007, 03:49 PM
  #8902
tony montana's Avatar
Trader Rating: 76 (100%+)
Well I finally got my rrr wce on the track today. Car seems to handle much better than my older cars. Only problem is I didnt hear it shiffting to 2nd gear. How do I adjust the 2 speed so it will engage.
tony montana is offline
Old 03-03-2007, 07:33 PM
  #8903
RoNTC3's Avatar
That does make sense. I'll try it. Thanks
RoNTC3 is offline
Old 03-03-2007, 09:39 PM
  #8904
There's 2 screws. Back them each out slightly for earlier engagement and tighten them for later engagement. I can't find a picture right now but there's 3 screws if I remember. the 2 outer ones control the shift point.
What you could try is holding the car from the roll bar and press the throttle gently and you should feel the car shift. It will have a bump and the front of the car will noticably want to pull up.
Sometimes I never hear it shift when I plant the throttle down. I have to roll the throttle gently to hear it.
Dredd is offline
Old 03-04-2007, 03:55 AM
  #8905
dr_catman's Avatar
Hope this helps to explain
File Type: pdf
dr_catman is offline
Old 03-04-2007, 06:51 AM
  #8906
thanks guys for the help. I'll turn out those 2 screws a little and see what happens
Old 03-04-2007, 07:19 PM
  #8907
Ivan Dickson's Avatar
Trader Rating: 32 (94%+)
Thumbs up
I had the same problem and I got some help at the track were I race and I was shown how to adjust the 2 speed it is very easy, screw in both screws all the way down then unscrew about 3 and half to 4 turns this should to the trick depending on how fast or slow you want it to shift, hope this helps.
Ivan Dickson is offline
Old 03-04-2007, 07:27 PM
  #8908
Sandra's Avatar
Chris here from C-Whits, if you get a chance just bring the car by the shop and I will get it straight for you.
Sandra is offline
Old 03-04-2007, 07:28 PM
  #8909
I'm having trouble with my clutch now. I had someone install the engine for me and the clutch was fine, but now after I took it apart and cleaned it I'm having trouble. Basically I have to rev the engine really high before it will engage which is bad and impossible to drive. I'm also not exactly sure how to adjust it. Is there a guide somewhere with a picture of what I adjust the spring tension with?
Dredd is offline
Old 03-04-2007, 08:08 PM
  #8910
mlaheyevo's Avatar
This is the clutch spring tension tool i use...... makes adjusting the spring tension very easy....as for the engine revving really high before it engages sound to me that the spring is adjusted to tight.....
http://www2.towerhobbies.com/cgi-bin...?&I=LXKYN1&P=6
mlaheyevo is offline
