Kyosho v-one rrr
#7471
Location: Costa Del Sol, Marbella, Spain www.bradir.net
rr evo chassis
nope, one of the biggest changes in the rr evo is the chassis, u can use this chassis if u will change ur rr to evo along with the evo front bulkheads, oneway and upperdeck, i suggest getting a 3 racing rr chassis only
#7472
Originally Posted by maskedrider
Any Picture to show how you guys fit your Transponder ?? And better way to hidden the wires.
I hope these help.
//BR[/IMG]
#7474
I realize I am a little behind the times, but I just bought an RRR WC and am looking for some good baseline setups. Our track is fairly open 140' X 80' and we treat it with a sugar water solution for traction (medium to high; depending on the temp and solution mixture) Any help would be appreciated.
John Hughes
John Hughes
#7475
John Hughes
John Hughes
Go ahead and try the box stock setup first. If that doesn't fit your needs, pm me and I can forward all my baseline setups to you. I have came up with different baseline setups (low, medium and high traction) from running at different tracks this year thus far. By your description on your track, I believe one of my setups would do well.
Dom
#7476
Guys,
Not sure if you guys have gone on Kyosho America Coming Soon page lately. RRR EVO parts are listed, so are the new spur gears with the harder materials!
Dom
Dom
#7477
Originally Posted by litespeed-dom
Guys,
Dom
Dom
#7478
John Hughes
John Hughes
jag
#7479
Originally Posted by jag
Good news...
Looks like what requires to do the top deck is
FM509B
VZ102C
VZ241
I just sent an email to our new team manager to confirm and also see if there will be a conversion kit for the U.S. shortly. I see that people are obtaining a conversation kit from overseas.
Will give you guys an update once I hear from them.
Dom
#7480
Hey all,
After months of owning the car, I only now discovered the adjustment for the front sway bars (the offset hole for bar height, not the tension) and the tool that adjusts it.
It goes higher and lower... but for the life of me I cant figure out why you would want to adjust it...
Anyone know why?
Anyone know why?
#7481
Originally Posted by Munkmotion
Hey all,
Anyone know why?
Anyone know why?
Dom
#7482
nice layout.... so your Transponder will be permenant fixed on your car ? And i been seeing others fixed on the Top plate which is right in front of the fuel tank...any different ?
maybe someone else might want to share their experience?
#7483
Hey all,
Anyone know why?
Anyone know why?
#7484
Better news is that all is available at Shopatron NOW!
FM509B
VZ102C
VZ241
Dom
FM509B
VZ102C
VZ241
Dom
What else is in the conversion kit?
Thanks for the info/update.
#7485
I honestly don't think I will be able to "feel" the difference when it comes down to the CG. I'm anticipating my brakes might feel a little different, hopefully a bit more modulation. Regardless whether it's the "way to go", I'll be doing the top deck conversion just because of the easy access to the throttle servo. And just because to try new things out, see it myself and put this whole "High servo CG" issue that everyone was complaining about to rest.
I'm anticipating the parts will be here next week.
Dom
Dom
