Kyosho v-one rrr
#7412
couldnt find the piece i needed so i just got a new pair of shocks lol. they are REALLY stiff though, is it bad for rear shocks to be stiff?
#7413
Raced the car today for the first time. Handled great. I had to play with the clutch a little bit in order for it to engage correctly.
I only finished one race but I qualified 4th out of 8 guys for the main, not bad. Running 50%.
#7414
Originally Posted by markp27
Here's my setup from the EFRA GP.
Cheers, Mark.
Cheers, Mark.
#7415
i think you have to change to the fantom/evolva shock bodies aswell
#7416
Hi Tommi,
Hmm, not sure why they don't fit for you - the springs are a little longer, but I can still run 65mm tyres and have 5.5 or 6mm ground clearence. I am using the standard shock bodies with standard ends
What droop setting are you running?
Cheers, Mark.
Cheers, Mark.
#7417
Hi Tommi,
Cheers, Mark.
Cheers, Mark.
#7418
Are their stronger steering rods and rear upper links for the RRR?
#7419
Kyosho has factory titanium steering rods.....3 racing makes titanium rear camber rods
#7420
I use the steering rods from the XRAY XB8 as they are the same lengths but made of hudy spring steel which is much stronger than the stock Kyosho part and use Lunsford 25mm Punisher turnbuckles as I run the rear links long with the optional rear brace VZW207, if you run the stock rear brace Lunsford also makes the links in a 20mm length.
#7421
Originally Posted by kidDynomite
Sorry these are MTX4 images.
#7422
Originally Posted by Data
the mtx-4 are fine, but a mac ?!?!? j/k
#7425
Originally Posted by maskedrider
Hi Mark, any picture to show ? I would like to know as well....
No Problem - I'll take some tomorrow.
Cheers, Mark.
