Kyosho v-one rrr
#7426
hmmm
look out its hot
#7428
Originally Posted by OVA
where did you get the rear sway bar?? Got parts numbers??
#7429
oops
#7431
Originally Posted by markp27
Hi Tommi,
Hmm, not sure why they don't fit for you - the springs are a little longer, but I can still run 65mm tyres and have 5.5 or 6mm ground clearence. I am using the standard shock bodies with standard ends
What droop setting are you running?
Cheers, Mark.
Cheers, Mark.
I've got no idea why it didn't work for me, I'm hoping to try out something new on the car this coming weekend. Previously I was running the gold rear long springs up front and silver front short springs on the rear with the longer shock ends, rear camber link in the "OUT" position, and the lower rear arm positioned at 2nd highest position; the car handled very well for me in my previous race, but things can only improve I guess.
WHen I put on the longer Fantom red rear springs, it seemed to me that the shock end and shaft is not long enough to give me enough of free downstop, even with the shock body adjuster at its highest possible position, I'm comfortable with 3-5mm of downstop, and upper shock mounting position at hole 2 or 3. I've messed around with the shock ends, mounting position, camber link and lower arm position, but things just didn't work like the way I want them to be; the ride height given by the longer spring is also too much for my liking. I'll get down to try to work around the car later, maybe I'll give more details on it.
On side note, the springs you used, is it the FM parts?
#7432
Talking about spring guys, can below springs fit into V1RRR stock spring adjuster and the stock shock body ? It indicated about the FMW24...
Evolva 1/8 spring
FMW12-418 Front Spring Light Blue (Use with FMW24 - Spring adjuster (14mm))
Evolva 1/8 spring
#7433
Hi,
where I can buy hopups of Kyosho and kawahara for my RRR? I'm from Spain, but i don't have problems to buy in internet.
thanks in advance.
thanks in advance.
#7434
Hi Mark, just an update after I got back to working around with the car again...of all the possibilities I've attempted to make the longer Fantom springs to work, I did not try it on with the stock shock ends......and it works! Must have been lack of sleep due to late night sleeps on WC matches and F1 race nights... My bad...thanks Mark!
#7435
Evolva 1/8 spring
Evolva 1/8 spring
#7436
Have you try on the Blue rear spring from Falcom ? and do you have that part number as well ?
#7437
hi, the rear diff in my V one RR has come apart 2 times in the past day... so i put some bigger screws in so that it wont come undone again. the problem now is that it feels like theres 100 000000 wt oil in them ><
#7438
chances are the screws you put in are hitting something and causing the diff the feel extremely tight... what it really sounds like you need is a new diff housing so the original screws that your suppose to use wont come loose...hope this helps..
#7439
problem is that around here in toronto ontario there are no hobby shops that carry kyosho parts
#7440
www.rctoro.com, www.rcmart.com, www.rcmushroom.com
hope this helps.
