Kyosho v-one rrr
#3001
Originally Posted by XBeta
thanks for the reply ziggy. however, you said only the middle screw fits. so would it like missalign itself much?
thanks!
thanks!
hope this helps
#3002
what's the difference between the Rear Suspension set VZ-004B and VZ-004C
#3003
Originally Posted by centax error!
xbeta- you need to do some mods by drilling new holes on the lola wide bumpers so you can secure it by using the 3 screws. Just be careful though because the new holes will be pretty much close to the existing outside holes. What I did was to start with the smallest bit you can get and go up until the screw will fit.
hope this helps
hope this helps
so you already have the lola bumpers on your RRR? When are you going to the track, I wanna see how it looks & fits. Thanks!
#3004
#3005
Originally Posted by joemugen
isnt mid to exit on power???
hey joemugen,this is the crew from maryland just saying whats-up and we will see you at the nats. also do you or anyone know where to get the adjustable ackerman for the rrr
#3007
Hey guys,
I would like to inform you all of this new feature on the kyosho website, it is a dealer locater. If you do not find a dealer near you, keep watching the website, it is allways being updated.
http://www.kyoshoamerica.com/locatedealer/Map.asp
#3008
#3009
an adjustable steering ackerman??? they do not adjust, the kit comes with three different ackermans that have different sensitivities. i would suggest you using the 11. hey, check out the mrx-4 forum. i posted pics of my new car. let me know what you think. show it to chris, i want to make him jealous
Joe,the RR had one and I was just wondering if there was one for the rrr,also there is one for the evolva,thanks though.
#3010
#3011
#3012
Originally Posted by jwf_frani
hi sandra, kawahara made an adjustable ackerman steering system for the rr evo and that fits right in on the RRR. But it adjusts the ackerman by moving the holes forward and back unlike the RRR 10,11, and 12 where the mounting holes are move in center going out
hi there thank you for responding, do you think this is worth trying to get,and also the pros and cons of it moving forwards and back, as opposed to left and right
#3013
Gee, i`d imagine moving the ackerman forward would create some clearance issues when a front diff/spool is fitted.
#3014
Let me bend some of you all ears, have a evo, just installed the rrr rear and front hubs on the car, what doe changing the roll center on the rear do to the handling of the car? as is I set it really close to the same angle as the old hubs, till I know what lowering the roll point will do. thanks.
#3015
