Old 11-16-2011, 04:54 PM   #586
peteR4's Avatar
Originally Posted by barg View Post
Are you using the steel crown gears? I bought some recently and they are absolute rubbish. I bought 4 sets at $25 a set and they are only the 2 main crown gears.
Well I ran these at our recent nationals and munched through 4 diffs as they do not mesh properly with the old small bevel gears.
I just got the hard diff cases this week and spent 2 nights trying to build a decent diff. The steel gears just wouldnt work no matter what I tried.
I eventually built the diff with all of the original internals and shimming to get it to be smooth.
I have yet to run the diff yet so I dont know if it will hold up but I have to say after running Kyosho for the last 10 years I am so over the rubbish they have bought out with this car.
If I have diff issues again this weekend I will be selling the lot and moving to a more reliable brand.
If you use hard diff case with steel crown gears and standard new small bevel gears you will absolutely have no problem. I run this diff about 7-8 liters and still are in a very good condition! Also you must put standard shim that came with standard gear set.
Capricorn C02 WC , Sanwa M11 , Capricorn engine , Capricorn tyres
peteR4 is offline   Reply With Quote
Old 11-17-2011, 02:43 AM   #587
Rubio's Avatar
Are you talking about using VZW412 on rear diff, correct? Is the front diff OK?
I'm still waiting to receive the kit, then if I correctly understood the first suggestion (almost compulsory) is to replace standard case of rear diff with vzw412, correct?
I read all of this thread and this seems the main issue to fix, other suggestion?
My Baby:
Nt1 '13/ MaxPower 3.5 / Savox Servos / HotRace Tyres / Sanwa Exzes Z
Rubio is offline   Reply With Quote
Old 11-17-2011, 03:00 AM   #588
nikoskar's Avatar
Front diff hasn't any issue from beggining.
If you don't want to replace kit's diff case then shim it with one more shim to both sides and wou will be ok.
www.rc-world.gr
nikoskar is offline   Reply With Quote
Old 11-17-2011, 04:19 AM   #589
peteR4's Avatar
Need hard case diff. Problem was also from diff case because it was very soft and when diff pushed the gap between gears opened...
Old 11-17-2011, 04:48 AM   #590
nikoskar's Avatar
Althought i have the hard front diff case i am using kit's front diff till today without any issues. (But will change to hard in future)
www.rc-world.gr
Old 11-17-2011, 09:19 AM   #591
LCM
Hello everybody, Hello Barg:
Iīm using standard pieces into the hard rear diff case. In the front diff, i havenīt had any issue whith standard parts, but i also use standard gears whith standard shimming whith hard cases. But only because i was given a set of both, front and rear hard cases, other way i would be using only the rear one.
Good luck.
LCM is offline   Reply With Quote
Old 11-17-2011, 10:52 AM   #592
Hey guys...I receive the hard case for diff... I never had a problem with the old ones since I bought the car in june... but all the coments make me insecure...so I bought the hard case...Now I'm building up the rear diff with the hard case... but I can't shim it properlly... can you tell me what shims did you use in your rear diff... with the standar case I used 0.3 mm shim on the diff case where you fill with oil and a 0.15 mm shim in the cover plate of the diff...
Thanks for help!!
P.D: If I don't use shims, the diff has play in the outdrives...
TomasRC is offline   Reply With Quote
Old 11-17-2011, 11:22 AM   #593
peteR4's Avatar
Thanks for help!!
My diff with original shims works perfect. I use hard case and steel gears. You must tight the cap good and see how it works. If everything is new maybe have a little tight diff but after some laps will work perfct.
Old 11-17-2011, 03:34 PM   #594
Yes, is a little feeling of rusty...I use the standar gears... ok... I will try... thanks!!!..
This weekend is the final stage of the national championship of chile... I'm in second place... surelly with R4 I will be the new national champ!!!...
Old 11-17-2011, 11:27 PM   #595
nikoskar's Avatar
And dont forget to change diff oils often than RRR.
www.rc-world.gr
Old 11-18-2011, 05:35 AM   #596
GREGORY!'s Avatar
Niko?can you weight your r4 diffs ready to run(without bearings) for me please?or any one else?
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 11-19-2011, 12:17 AM   #597
E Vasutin's Avatar
Put a .3mm shim in addition to the provided spacers in the rear diff cup. Diff cup being the key word. That solves the gear mesh in the rear diff. The front diff is shimmed appropriately.
Lower the servo by 2.5mm and move it as close to the center of the chassis as possible. Use a normal servo horn and the steering travel will be correct.
The tank is mounted with too much vibration for proper pit stops (erupts fuel when pitting), so dremel the tank slightly so it's clear of the carry handle (roll bar). This tank is mounted on 3 points, make sure the tank is fitted loosely to the radio tray (enlarge the tanks holes slightly).
E Vasutin is offline   Reply With Quote
Old 11-21-2011, 11:44 AM   #598
Hey guys!!! guess what?...R4 win the Chilean National Championship!!!...Six Stages!!!...I'm the National Champion!!!!...yeah yeah!!!
Thanks guys for all helpfull tips!!!...
Now I'm trying to achieve the Copa del Pacifico Challenge in Peru... on march... so I'm preparing for that!!!
Kyosho R4 rules!!!
Old 11-21-2011, 01:21 PM   #599
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
Kyosho R4 rules!!!
gongrats good job!
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "TKI4 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / PROTEK / FUTABA 4PX / SAMURAI
1evo RRR Driver is offline   Reply With Quote
Old 11-21-2011, 03:07 PM   #600
nikoskar's Avatar
Kyosho R4 rules!!!
Congratulations Tomas.
www.rc-world.gr
**NSWRCRCC Inc. - Moorebank On-Road** VenomWorldOrder Australian Racing 11447 11-30-2017 04:03 AM
Kyosho FW-05R Finnitro Nitro On-Road 5443 02-07-2017 11:10 AM
Kyosho V-ONE RRR EVO 2 boy2rc Nitro On-Road 2803 10-04-2014 12:50 PM
Kyosho V One Series Prototype (;) nikoskar Nitro On-Road 78 12-16-2010 04:07 AM
