Kyosho v-one r4!!!! >
Kyosho v-one r4!!!!
Like Tree26Likes
Kyosho v-one r4!!!!
Old 05-12-2011 | 04:14 PM
  #331
Speedypeterb's Avatar
Default diff gears
Originally Posted by barg
Any updates on when the hardened diff gears are coming out?
we will be testing this weekend with the shimming of the rear diff willl post results after the weekend
Speedypeterb is offline
Old 05-12-2011 | 07:01 PM
  #332
yukiyu's Avatar
Good luck my friend , have fun !!!
yukiyu is offline
Old 05-13-2011 | 07:06 PM
  #333
Default Diffs
Today we ran about 30 minutes with no problem we will post after tomorrow qualifing
Old 05-13-2011 | 07:37 PM
  #334
yukiyu's Avatar
Peter , can you please post the step by step build up of the rear diff. and the shimming ? , thank you brother and good luck!!
Yukiyu
yukiyu is offline
Old 05-14-2011 | 08:35 PM
  #335
Default Shimming r4 diff
So far this is how we shimmed the diff, we put a .3mm shim5x7 inside the diff on the outdrive shaft on top of the supplied shim
Before the pin install. So far no problems after half a gallon.
We also shimmed another diff diferently but won't be able to test till next weeks race in conn. We will post the results here.
Old 05-15-2011 | 02:51 AM
  #336
alangking_306's Avatar
sorry to say that i have no problem with the diff after 2 race in johor malaysia
actually my problem is looking for better setting,conner to big anyone have good setting to share t.q bro
alangking_306 is offline
Old 05-15-2011 | 04:34 PM
  #337
barg's Avatar
Hey guys,
I also built 2 new diffs for yesterdays club race. I doubled the standard shims on each side. Rear diff felt a little tighter but they ran fine all day.
Qualified 2nd and won the 30min A final by 3 laps.
I pulled apart the diff I blew 2 weeks ago and it had snapped the main crown gear where the pin sits. I did have a big accident with my car during that meeting so I think that may have contributed.
Yesterday I had no accidents at all and diffs ran fine all day.
barg is offline
Old 05-17-2011 | 08:51 PM
  #338
yesterday bashing then hit fencing column at the top,but then use hand and hammer to repair it and bashing again hehehe car very fast at top...
Attached Thumbnails Kyosho v-one r4!!!!-img_1103.jpg   Kyosho v-one r4!!!!-img_1104.jpg   Kyosho v-one r4!!!!-img_1105.jpg   Kyosho v-one r4!!!!-img_1106.jpg
Old 05-18-2011 | 04:12 AM
  #339
nikoskar's Avatar
You can user softer front diff oil or harder rear diff or change caster settings or another body or..or...or...
nikoskar is offline
Old 05-28-2011 | 01:05 AM
  #340
Bundy_Bear's Avatar
Noob question... is this kit really a limited edition?
Bundy_Bear is offline
Old 05-28-2011 | 05:48 AM
  #341
Default limited
the limited edition is because it comes with extra set of lower arms and the option spur gears.
Old 05-29-2011 | 05:42 PM
  #342
peteR4's Avatar
What's happening with that car? I haven't see wet any good race result. Many companies have release a lot of optionals for many cars but nothing for R4 wet.
The car does not need many optional. Just an aluminium brake holder and....harder diff gears.
I read many dissapointing comments for the rear differential and i didn't see any interest fron kyosho.
A lot of racers who waited to buy a new car (like kyosho R4) now are confused.
I hope to see a solution very soon.
Also I hope to see burst of victories.....
peteR4 is offline
Old 05-29-2011 | 06:19 PM
  #343
I happen to be sitting in that boat
That's why Im heading towards getting a 733 evo.
If I was to get the R4, I would scour this thread to see if there is anything else I would need to do apart from making sure the rear diff is nice and snug-fitting.
DJ_Shakespear is offline
Old 05-29-2011 | 06:32 PM
  #344
barg's Avatar
I have only had 2 issues with the car. The first was the clutch nut coming loose. Easy fixed with some loctite.
The 2nd issue was the weak diff gears. I have been told that the hardened diff gears will be released by Kyosho sometime in June.
In terms of getting a 733 I think you will have more problems than this. I had a 733 last year for about a month and the list of problems with the car were almost 2 pages long.
barg is offline
Old 05-29-2011 | 07:52 PM
  #345
Michael_T's Avatar
Didn't you win on debut with your 733 ?
Michael_T is offline
