Old 06-06-2011, 03:16 AM   #361
peteR4's Avatar
Originally Posted by speed6 View Post
Soooooo finally i manged to ru the R4.
The 2nd didn't want to engage and yes everything was clean and degreased.
I ended up unscrewing almost half a turn more than the manual says in order to kick in, but the screws are touching a bit the aluminium housing and obviosly did some grooving. Also it doesn't feel consistent sometimes it shifts with certain revs someother times it shift earlier etc....
After cleaing the car i took out and inspected the 2nd for the (around) 15th time and smoothened the screws in order not to touch.
On our local track the cars still feels that needs more steering.
In order to get better steering i did the following:
I installed softer shock (light blue) lighter oil 300wt vs the stock 400wt
Installed front shocks on the lower hole of shock tower.
Caster with out spacers up front.
Moved the rear shocks to an upper hole by one space.
Reduced a bit the toe in in the rear ( 0.25 degree )
Running 37 front and 40 rear
I still want some more steering and thought of the follwing:
I am thinking of going for harder springs in the rear (dark blue) with 450 wt shock oil.
Less Toe in in the rear but might be not stable.
Running 35 Front and 40 rear
What do you suggest?
You can use 100.000 silicone oil at rear diff. I will try 200.000 xray rear... Also you can use 4mm spacer under the rear hubs links...
Capricorn C02 WC , Sanwa M11 , Capricorn engine , Capricorn tyres
peteR4 is offline   Reply With Quote
Old 06-06-2011, 01:45 PM   #362
Angel Santiago's Avatar
HI I RECENTLY BUY MY KIT AND START TO BUILT. EVERYTHING IS OK UNTIL I START TO BUILT THE TRANSMISSION. I NOTICE THAT THE BEARING IN THE 2ND GEAR IS LOOSE IN THE VZ430 THAT'S THE PART NUMBER. I DON'T KNOW IS THERE SOMETHING WRONG WITH THAT PART OR SOMETHING BAD WITH THE BEARING. I TRIED OTHER BEARING WITH THE SAME DIAMETER FROM MY OLD RRR AND ITS THE SAME THING.. THANKS FOR ANY HELP..
YUKIYU CALL ME 787-615-1169
Angel Santiago is offline   Reply With Quote
Old 06-06-2011, 02:17 PM   #363
nikoskar's Avatar
It's not a problem. Is working that way. Different than RRR.
www.rc-world.gr
nikoskar is offline   Reply With Quote
Old 06-06-2011, 04:47 PM   #364
barg's Avatar
Send a message via Yahoo to barg
Yeah this is totally normal. Mine is very loose also and flops around a bit but it works fine and I have not stripped any gears and I have ran the car for around 8 days now.
Just make sure you mesh the gears as tight as possible like on the RRR but without it binding.
XRAY NT1-2015 Spec | Max Power Engines | KO KIY EX10 | Protoform | Matrix Tires | XRAY X12-16
HEI International | www.hobbyexpress.com.au
www.nswrcrcc.com
barg is offline   Reply With Quote
Old 06-06-2011, 05:30 PM   #365
peteR4's Avatar
Its not right... You must put o spacer between the 1st and 2nd gear. the gap is very big and the 2nd gear touch the 1st gear resulting in some times cutting 2nd gears... the spacer must put not at the axle but above to the 1st oneway. I use a plastic spacer from....RRR pulley set. I Drill the hole and also use a sandpaper to make the spacer thinner. Thikness must be around 1-1.5mm...
Transmition works good. The only think needs when its new is to use a thin sandpaper to scrach a little the 2nd gear bell and shoes. Also 2nd gear bearing-bell-shoes must be completely clean from grease-oils...
Old 06-06-2011, 11:39 PM   #366
nikoskar's Avatar
ok.
www.rc-world.gr
Old 06-07-2011, 12:10 PM   #367
Angry
Thank you guys for your tips I hope that i can run the car these weekend because there is a lot of rain in Puerto Rico........
I'm going to try the shim in the transmission ......
Old 06-07-2011, 05:12 PM   #368
peteR4's Avatar
Now its time to say us your tips for a good rain setup!!
Old 06-07-2011, 09:03 PM   #369
GMartinez's Avatar
Trader Rating: 85 (100%+)
Have a friend who is looking to off load a really nice pkg
1 R4 with 3 races on it
1 R4 Kit
over $700 in parts
$1,200 shipped pm for pics
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 06-08-2011, 12:01 AM   #370
nikoskar's Avatar
Stay home and sleep.
www.rc-world.gr
Old 06-08-2011, 03:37 AM   #371
Rubio's Avatar
1 R4 Kit
over $700 in parts
Another happy user of that car...
My Baby:
Nt1 '13/ MaxPower 3.5 / Savox Servos / HotRace Tyres / Sanwa Exzes Z
Rubio is offline   Reply With Quote
Old 06-08-2011, 07:07 AM   #372
blount's Avatar
1 R4 Kit
over $700 in parts
Someone tapping out already!!!lol
Serpent America
Desoto Racing
Runner Time Fuel
Matrix Tires
SRC
blount is offline   Reply With Quote
Old 06-08-2011, 09:01 AM   #373
Usually in the Caribbean there's a lot of sun all the year, in these days there is some bad weather around us. Is raining for about 2 weeks. Next Sunday is the next race for our local track. I'm running kyosho car for about 8 years fw-05rr, rrr, rrr evo until now with lot of confidence in the kyosho cars. I'm going to try the new r-4 to see if i make better laps time than the RRR evo. As i said and see in some forums that there are some issues that make the car something to think about it like the diff issues and the 2nd spur gear, eventually I see good potential in this car. I'm going to post every tips that i made in mine very soon...
And its still rain the next Sunday i prefer to run my inferno gt that is a class that it is strong in here . the past race ill make the t.q but the rain goes on and they cancelled the race
Old 06-08-2011, 09:48 AM   #374
Lol....
Capricorn America , RC Target , Kosmic Fuel , RPM Hobbies , Express Motorsports , Murnan Modified , BrokeasJokeRacingTeam.
yukiyu is offline   Reply With Quote
Old 06-08-2011, 12:30 PM   #375
nikoskar's Avatar
Regarding the shimming of the diffs. Please look at the last page of the manual (the parts page) and you'll she that the UM610 code the shims are 0,50mm and not 0,10mm or 0,15mm that are including in the kit.
If you have any problem you could add shims to bottom and top, then close the diff and check if it spins.Add shims as many as when you add 0.1mm more the diff not working free.
www.rc-world.gr
**NSWRCRCC Inc. - Moorebank On-Road** VenomWorldOrder Australian Racing 11447 11-30-2017 04:03 AM
Kyosho FW-05R Finnitro Nitro On-Road 5443 02-07-2017 11:10 AM
Kyosho V-ONE RRR EVO 2 boy2rc Nitro On-Road 2803 10-04-2014 12:50 PM
Kyosho V One Series Prototype (;) nikoskar Nitro On-Road 78 12-16-2010 04:07 AM
