Kyosho v-one r4!!!! >
Kyosho v-one r4!!!!
Like Tree26Likes
Kyosho v-one r4!!!!
Old 09-29-2011 | 01:17 AM
  #481
nikoskar's Avatar
Originally Posted by speed6
When you said that the rear follows the front more easily using what setting on the new rear end arm parts? Also is position in the middle hole exacly in the same position as the middle stock part?
Stock position. next time try to change position in order to see how it works.
Yes Kyosho need drivers for Europe.
nikoskar is offline
Old 09-29-2011 | 01:22 AM
  #482
nikoskar's Avatar
Originally Posted by rcabj
my fren just blew up another set of his gear diff...
  • Inform him to add 1 more shim to top and bottom of diff case and fill with oil 100%.
  • After 2 days of practice you need to replace the oil. It's not the same as RRR.
nikoskar is offline
Old 09-29-2011 | 02:48 AM
  #483
Default motor mount
hi,
Anybody knows that vzw406 fits novarossi engines??
halukso is offline
Old 09-29-2011 | 03:02 AM
  #484
nikoskar's Avatar
Originally Posted by halukso
hi,
Think is common. Doesn't say that fits only one engine.
nikoskar is offline
Old 09-29-2011 | 04:43 AM
  #485
vz444 does not fit xceed(mega) based engines!!
i use VZW065 with my nova .12pts,, and manifold touchs middle belt,
engine sits a little bit lower.. help me anyone faced with this problem!?
halukso is offline
Old 09-29-2011 | 05:01 AM
  #486
nikoskar's Avatar
VZW065 is almost 0.5mm higher than vzw406.
nikoskar is offline
Old 09-29-2011 | 05:57 AM
  #487
peteR4's Avatar
Tight al little bit more the middle belt...
peteR4 is offline
Old 09-29-2011 | 07:38 AM
  #488
I didn´t have any problem with rear diff... a friend has, and he shimmed, but it didn`t fix... so we start to look very carefully to the car... and he makes a mistake... the fuel tubbing that put inside the rear diff cups makes a lot of presure to the dogbone...so, when the suspension compress, the dogbone makes a lot of force over de diff cups and was transmited to the diff gears, breaking it...
Hope that to be helpfull...
My R4 is a mounster!!! jejejej
TomasRC is offline
Old 10-02-2011 | 02:39 PM
  #489
nikoskar's Avatar
Received 4 steel gear diff and new rear diff case here in Greeece from our Local Distributor in order to add them for our National Championship on Sunday.
Photos tommorow.
nikoskar is offline
Old 10-03-2011 | 06:19 AM
  #490
Photos tommorow.
4???? I thought they were 1 pair for each of us....that equals 3 pairs of steel diff gears , you , kirkos and me....who got 2 pairs?????
nickiphorosn is offline
Old 10-03-2011 | 01:11 PM
  #491
nikoskar's Avatar
Some faster than you.
nikoskar is offline
Old 10-07-2011 | 03:02 AM
  #492
MikaR's Avatar
Photos tommorow.
Ok, tomorrow yet ;-) How did it go?
MikaR is offline
Old 10-07-2011 | 02:03 PM
  #493
Speedypeterb's Avatar
Default diff case
I have received the updated plastic diff case will be running this weekend will let you know. I have not gotten the steel diff gears yet, I did run the old one that was in the kit and it lasted three races all practices and qualifiers and a-mains, it broke at the last race 20 minutes in the main. when i built the diff i had to dremel some of the small gears free of little burs when you build put it together dry and make sure of smooth operation.
Speedypeterb is offline
Old 10-09-2011 | 02:32 PM
  #494
nikoskar's Avatar
Sorry for the delay but today was our local championship and was tyred.
With the new rear diff case and steel diff gears you can you the default shimming.1 top and 1 bottom.
The steel diff gears seems to have diaper cut and working better.
We also need to replace front diff gear too. No problem but steel gear is better than stock.
nikoskar is offline
Old 10-11-2011 | 06:23 PM
  #495
Default diff gears
I ran the new case with the old gears (haven't got the steel gears yet) i shim .1 behind 2 of the four small gears, i tried 4 shims but it was to tight so i tried the 2 and it work fine all weekend we had rain so i was limited to about 20 minutes of track time so i will run again n two weeks and let you know. mine diff leaked but it was deffinely because i over filled it. I will put a little less fluid next time. note my two speed wobles but I have not had any problems with the gears.
