Old 10-11-2011, 11:37 PM   #496
nikoskar's Avatar
Originally Posted by Speedypeterb View Post
I ran the new case with the old gears (haven't got the steel gears yet) i shim .1 behind 2 of the four small gears, i tried 4 shims but it was to tight so i tried the 2 and it work fine all weekend we had rain so i was limited to about 20 minutes of track time so i will run again n two weeks and let you know. mine diff leaked but it was deffinely because i over filled it. I will put a little less fluid next time. note my two speed wobles but I have not had any problems with the gears.
No need to shim small gear. Add one more shim to top and bottom big gear, fill full with oil,work a little the diff, let it rest and screw 3 of 4 screws and let a little oils to pop and then screw all of them. You are done with no leak and problem.
Or if you buy new diff case then you shim default (1 up and down)
www.rc-world.gr
nikoskar is offline   Reply With Quote
Old 10-11-2011, 11:59 PM   #497
barg's Avatar
Send a message via Yahoo to barg
Is the new diff case the alloy side one?
XRAY NT1-2015 Spec | Max Power Engines | KO KIY EX10 | Protoform | Matrix Tires | XRAY X12-16
HEI International | www.hobbyexpress.com.au
www.nswrcrcc.com
barg is offline   Reply With Quote
Old 10-12-2011, 12:42 AM   #498
nikoskar's Avatar
It seems that the material is little harder but there is a difference from inside. Also in order to recognize the new one at the back there is a design like the logo of Team Orion. Will upload a photo of it in the afternoon.
www.rc-world.gr
Old 10-12-2011, 03:55 AM   #499
RC MARKET's Avatar
Kyosho released new Hard Diff. case & cap
rcmarket.com.hk
RC MARKET is offline   Reply With Quote
Old 10-20-2011, 12:10 AM   #500
barg's Avatar
Hi guys.
I bought the vzw409 rear suspension mounts. Can someone explain how they change the roll centre as they look the same to me as I only have the centred plastic bushings......
www.nswrcrcc.com
Old 10-20-2011, 12:17 AM   #501
barg's Avatar
Originally Posted by peteR4 View Post
VZW409 effect rear roll center because you can change arms height. But also change the width of rear arms. Car is very fast and every race go faster because of new things we find to make the setup better. The only think i try to find is to make the rear of the car to rotate . Car is understeering and i think that is because of rear too much handling...
How?????
www.nswrcrcc.com
Old 10-20-2011, 04:52 AM   #502
peteR4's Avatar
How?????
What you mean how??
Capricorn C02 WC , Sanwa M11 , Capricorn engine , Capricorn tyres
peteR4 is offline   Reply With Quote
Old 10-20-2011, 05:30 AM   #503
barg's Avatar
What you mean how??
How does this part change the roll centre?
www.nswrcrcc.com
Old 10-20-2011, 03:37 PM   #504
peteR4's Avatar
This part let you change the height of rear lower arms. So you can change roll center.
Also you need plastic part with different hole position to change the height.
Old 10-21-2011, 03:04 PM   #505
barg's Avatar
Ah ok. That makes sense now. Thanks. What is the part number for the offset plastic part as they don't come in the kit for the rear only the front which are too big.
www.nswrcrcc.com
Old 10-21-2011, 08:16 PM   #506
peteR4's Avatar
You must buy VZ410. So you can change also front roll center. The only think you must always see is the width of the car because when you change the lower arm height you also change arm width...
Old 10-26-2011, 10:47 AM   #507
peteR4's Avatar
Cool
Anybody have a good place with R4 in a race event? Can we have a compare (about how fast is the car) with other cars??
Old 10-26-2011, 03:16 PM   #508
nickiphorosn is offline   Reply With Quote
Old 10-26-2011, 04:51 PM   #509
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
Default R4 vs!
I could be wrong, but rightnow I don't think anybody who switched from RRR to R4 is actually going any faster.......atleast the few I've seen at our track!!
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "TKI4 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / PROTEK / FUTABA 4PX / SAMURAI
1evo RRR Driver is offline   Reply With Quote
Old 10-27-2011, 04:37 AM   #510
peteR4's Avatar
Originally Posted by nickiphorosn View Post
Here is my friend the best ever kyosho R4 race result
The best nitro 1/10 driver in GReece with its mechanic PAnos KIrkos got the pole and the second place in podium
http://www.rc-world.gr/nikites-gas-open-25-sep-2011
Thanks to my sponsors , i" ll keep up with the good results
Nikolaos Nikiforos
Guy who took 1st place is fast?
**NSWRCRCC Inc. - Moorebank On-Road** VenomWorldOrder Australian Racing 11447 11-30-2017 04:03 AM
Kyosho FW-05R Finnitro Nitro On-Road 5443 02-07-2017 11:10 AM
Kyosho V-ONE RRR EVO 2 boy2rc Nitro On-Road 2803 10-04-2014 12:50 PM
Kyosho V One Series Prototype (;) nikoskar Nitro On-Road 78 12-16-2010 04:07 AM
