Serpent 710
Old 09-03-2004 | 12:08 AM
  #14956
crashed_1's Avatar
Originally posted by InitialD
What do you mean be careful with the fit? What is tight? Their sitting into the casing?
I still get lost with or without a map ! I plan to go in the morning about 9 to 10 (my morning that is ).
Will explain when i see you...it's more their sitting on the shaft and crankcase. You did mention it being tight right?
You won't get lost. take the same route to go Andalas but on the last flyover where it heads to Banting, go down left instead and follow signboards to Jln Istana. There'll be a roundabout with 6 exits...looks like a turtle on the signboard.
From there on stick your nose out the window and follow the scent of the fumes...
crashed_1 is offline
Old 09-03-2004 | 12:12 AM
  #14957
crashed_1's Avatar
Originally posted by markp27
That's your main bearing D also used a Jedi Mind trick, to make you think it was the ring
That figures why my ring keeps spinning on my fingers.
Old 09-03-2004 | 12:24 AM
  #14958
spawn's Avatar
Damn. I thought I could keep a secret but you surely know when to creep in and out to dig secrets.
how much did the KHM crankshaft cost you? is this the hardened one?
spawn is offline
Old 09-03-2004 | 12:25 AM
  #14959
I know Goldfinger mentioned to me that the Boca front ceramic bearing is not soo reliable and therefore discouraged me to get it. I only got the main bearing.
So you dont pass that info to your wing man on purpose ?
About that KHM shaft, I still dont understand why my personal modded shaft (exactly same timing with KHM) still can not match the genuine one. Especially in mid-above rpm.
GoldFinger is offline
Old 09-03-2004 | 12:31 AM
  #14960
spawn's Avatar
Originally posted by crashed_1
The RR12...just got a new set of p/s... Damn bearings. The bearings are hard...the case that holds them are not. Be extra careful with the fit. Anyways, what time are you planning to go?...It's quite easy to get there. I think theres a map on the Klang thread...
whew!, lucky I decided against changing the bearings in my NSR.
spawn is offline
Old 09-03-2004 | 12:36 AM
  #14961
spawn's Avatar
could it be due to the turbo scoop and the diameter of the inner hole of the crank. The KHM crank ID looks rather big.
spawn is offline
  #14962
InitialD's Avatar
Only on a need to know basis.
Maybe something to do with the balance? You like your KHM shaft very much? I still have not tested mine.
I notice that compared to the NovaMax one, the opening on the KHM is slightly wider still ! I don't have a protector to gauge in degrees how big it was opened but my guess it's about 2 to 3 degrees more than the NovaMax. More advance timing.
Anyway, it is common for the main ceramic bearing to be very tight when fitting the crankshaft in?
InitialD is offline
Old 09-03-2004 | 12:39 AM
  #14963
InitialD's Avatar
I think when Goldfinger mentioned that he did the same thing on his on crankshaft, he meant that everything was the same.
Anyway, I thought the scoop on the Max is slightly bigger. Else, everything else is the same cut except on the timings.
InitialD is offline
Old 09-03-2004 | 01:07 AM
  #14964
[/QUOTE]
Maybe something to do with the balance? You like your KHM shaft very much? I still have not tested mine.[/B][/QUOTE]
Could be, actually it was the only excuse I had
I like it very much, especially in the mid-range. Very very linear.
Intake periode is actually the longest one IMHO.
The downside is small scratch will affecting performance so much.
Just like the FX ones. Extra attention on the air filter is a must.
[/QUOTE]
Anyway, it is common for the main ceramic bearing to be very tight when fitting the crankshaft in? [/B][/QUOTE]
Yeah, tighter than Novas one
Old 09-03-2004 | 01:37 AM
  #14965
Default New Anti roll bar
Sorry if you guys have already bought this up but i have just recieved my new rear anti roll bar looks very nice will test it tommorow
Brett.w is offline
Old 09-03-2004 | 01:41 AM
  #14966
InitialD's Avatar
Default Re: New Anti roll bar
Woow ! Where did you get that from? How much? I don't think Serpent made an adjustable one.
InitialD is offline
Old 09-03-2004 | 01:43 AM
  #14967
Default JP in 710
Just one other thing, i have bought a JP FX 12 (black case) and was just wondering if anybody else was running one? It is just after 15 tanks is is still very slow, it is not getting to top revs. I am just wondering if anybody else has had this problem? I have tried adjusting the high speed needle but to no avail any ideas?
Brett.w is offline
Old 09-03-2004 | 01:45 AM
  #14968
Default Re: Re: New Anti roll bar
Good old RC mushroom
http://rc-mushroom.com/product_info....oducts_id=3738
Brett.w is offline
  #14969
InitialD's Avatar
Default Re: JP in 710
What pipe are you using? Has the engine been broken in fully?
InitialD is offline
Old 09-03-2004 | 01:47 AM
  #14970
Default Re: Re: JP in 710
RD turbo 3 with 2 inserts
Brett.w is offline
