Serpent 710
Old 08-23-2004 | 07:25 AM
  #14806
can anyoen post me a pioc of there brakes ont here car? so i can see if mine is correstly put onthank you to whoeevr does it
Bxclip is offline
Old 08-23-2004 | 07:32 AM
  #14807
packetdreamer's Avatar
you have a PM.
packetdreamer is offline
  #14808
Sow&Steady's Avatar
Originally posted by markp27
Won't be possible, D. If I lift my leg to kick Sow (assuming that my arthritis allows my leg to get that high ) then I'll loose my balance on my walking stick. Likewise if Sow tries to kick my ar*e - he'll probably also end up falling over.
I think it is better we do like all old-folks, i.e. just stare very meanly at each other.....but there again, with our poor eye sight, we'll probably be only staring at a lamppost or something
How right you are. I certainly had my nearly stare and wrapped around a fence post yesterday!
Sow&Steady is offline
Old 08-23-2004 | 12:47 PM
  #14809
Default grease on rear diff????
has it ever been suggested that you put grease on the rear diff balls? doesn't sound proper to me, but i just want to know if i'm off track or something.
Old 08-23-2004 | 12:58 PM
  #14810
markp27's Avatar
Default Re: grease on rear diff????
I prefer to use a small amount of grease on the diff balls. Best of all refer to the build instructions in the FAQ section 4.
markp27 is offline
Old 08-23-2004 | 01:19 PM
  #14811
Default Re: Re: grease on rear diff????
in the instructions, i don't see anything about putting grease on the diff balls. julius preferes not to use grease (but for those determined he suggests that you use a sticky type but use very little), and i don't think glenn say sanyting about lubing the diff balls...
o well, we take what we can use and toss the rest out i suppose. THANKS!
Old 08-23-2004 | 03:15 PM
  #14812
Sow&Steady's Avatar
Default Re: Re: Re: grease on rear diff????
I've built two 710s, the first one I did not use any grease as per instructions. It was smooth for 2 races before going a little gritty. Each race consist on three 5 minute heats and finals were 1 hour long. There were a few practise runs in the weeks in between.
The second car, I used Mugen SuperGrease and so far it is still silky smooth. I've done two club races with it, each race consist of four 5 minute heats and 10 minute finals. There were a lot of mucking around in the weeks in between.
I vote for the second one ... lightly greasing the diff balls with Mugen grease.
Incidentally, for the first car I also built a front diff using the Mugen grease ... still silky smooth.
Old 08-23-2004 | 03:18 PM
  #14813
Sow&Steady's Avatar
Originally posted by jfc_tech
just wanna make my mark here again. i had assembled the kit already and ready to rumble on track. i miss the fast & furious of on-road touring. after all, serpent is still the dominating force here. i wish they come out with a monster truck kit
Welcome back!
Old 08-23-2004 | 10:05 PM
  #14814
markp27's Avatar
In section 4.4 of the FAQ, there are links to articles from Julius and Glenn - if you read the one from Glenn, you'll see he recomends using grease on the diff balls. It is a preference thing and you certainly don't need to do it - but you'll probably find that the diff remains smoother longer when you use grease (Mugen Super Grease)
step 2.9 from Glenn's instructions
2. Place a small amount of diff lube in the palm of your hand, then roll diff balls in it to coat them lightly.
markp27 is offline
Old 08-23-2004 | 10:43 PM
  #14815
Default Re: Re: Re: Re: grease on rear diff????
thanks!
Old 08-23-2004 | 11:08 PM
  #14816
Default Re: X-ray cvd's
Originally posted by 840918001
Hi,
Has anyone tried to use the X-ray Factory kit cvd axles on his Serpent 710?
I have downloaded the X-ray FK manual, and the bearings in the C-hub off the X-ray have the same size as the Serpent bearings.
Are the X-ray cvd's long enough? If not this is a nice hop-up
Thank you in advance,
Thomas
Our local 710 drivers have been using xray cvds to combat our problem.Yes you can use it but it requires using many xray parts.
Zizu is offline
Old 08-24-2004 | 12:04 AM
  #14817
markp27's Avatar
Default Re: Re: X-ray cvd's
Which problems do the CVDs overcome?
Cheers, Mark.
markp27 is offline
Old 08-24-2004 | 12:06 AM
  #14818
border r/c's Avatar
Default New rims
he guys the new rims are in stock but with foam complete we have to wait a little Serpent has only the new 1/8 in stock on the moment as soon there ready i will post it
border r/c is offline
Old 08-24-2004 | 12:09 AM
  #14819
markp27's Avatar
Default Re: New rims
Thanks for the info
markp27 is offline
Old 08-24-2004 | 12:22 AM
  #14820
InitialD's Avatar
Default Re: Re: New rims
Thanks for the info
Hey, just buy them for the Vector then.
InitialD is offline
