Serpent 710
Old 07-06-2004 | 04:57 AM
  #13606
C-spec, another.
If you want to see any others I'll take some more when I've cleaned it from the weekend.
Craig1 is offline
Old 07-06-2004 | 05:04 AM
  #13607
markp27's Avatar
Originally posted by Craig1
C-spec, another.
Yes please Some nice close-ups if it is possible, so I can see in detail what you've done.
Cheers, Mark.
markp27 is offline
Old 07-06-2004 | 05:12 AM
  #13608
rcpanama's Avatar
Originally posted by PSI Racing
Where can you buy those 850 mAh batteries?
In EBAY
http://cgi.ebay.com/ws/eBayISAPI.dll...825890667&rd=1
rcpanama is offline
Old 07-06-2004 | 05:35 AM
  #13609
This is about the only close up I've got at present.
Craig1 is offline
Old 07-06-2004 | 05:37 AM
  #13610
markp27's Avatar
I'm sure Sow&Steady would like it if you wrote an article about your C-Spec for his website www.3hobby.com
I would certainly like to read more about your mods
Thanks for the pics, Mark.
markp27 is offline
Old 07-06-2004 | 07:33 AM
  #13611
teammpp's Avatar
The 850mah I use for the receiver pack are made up using GP cells. I dont think you can buy an 850 pack pre-made (not seen one anyway).
teammpp is offline
Old 07-06-2004 | 11:59 AM
  #13612
rcpanama's Avatar
That is correct the 850 pack I am using I built my self from 850 GP and SANYO which I bought in EBAY
rcpanama is offline
Old 07-06-2004 | 12:33 PM
  #13613
lagnaf's Avatar
Default Silicone tube for dogbones
Hi racers
I'm rebuilding my snake after a Sundays race.
I was third and it was my first race with 1/10 nitro car.
Here are some pictures
http://mdm.zrcalo.si/forum/viewtopic...er=asc&start=0
Back to the question.
I wont to know about the silicone tubes inserted beetwen the dogbones.
How much should I put it in.
Should I put it yust in front or to rear d.bones to?
I now there was a thread about this on this forum but I yust cant find it.
Maybe someone can post a link.
Cya
lagnaf is offline
Old 07-06-2004 | 03:27 PM
  #13614
As said before, i have a oversteer on corner exit problem. I want to change springs as a last ting. And i wonder, will standing the front shocks more vertical, pos. 3-4 give the car less"bite" in the turn, and cure my problem?? Changing to harder shore is another sulution right? and less caster?
Finken is offline
Old 07-06-2004 | 06:43 PM
  #13615
TitaniumR's Avatar
Default Front Droop
Hello to all,
I just joined the crowd here with the 710. I understand from local drivers that its front droop will change at impact because the upper bumper holds the droop screws. What are your ways to recitify this problem? I've seen 3racing's graphite upper bumper but that's gonna crack easily.
Thanks for your help.
TitaniumR is offline
Old 07-06-2004 | 07:31 PM
  #13616
wolfejohne's Avatar
Assembly Questions
I am installing the new 802235 Spacers for Steering Blocks and Rear Uprights and I have a few questions.
1. I have heard that some people have had problems with the spacers causing the bearings to spin in the uprights. Is this so and what caused the problems?
2. When you install the spacers they sit between the inner race of the two ball bearings, do you set the endplay for the wheel axle snug (no lateral play) or a very small amount of endplay when you position/tighten the wheel-adaptor hex?
Differentials?
1. When you assemble the front and rear differentials what do you use to lube the ball bearing #1326, Serpent Bearing oil or Mugen Super Grease?
2. Do you lube the friction surface between the pulley and diff axle and what do you use?
3. When I was putting the front diff together I noticed that it did not use the o-ring #1065 and Spacer #801436 to hold the friction collar to the pulley. My front diff came with a outside snap ring to hold the friction collar on. What is the preferred method for the front and rear differentials?
wolfejohne is offline
Old 07-06-2004 | 07:44 PM
  #13617
InitialD's Avatar
Default Re: Front Droop
Nope. The graphite bumper has not buckled or cracked on me yet ! <touch wood> Of course you cannot expect miracles if you crash head on to the wall. For what it's worth, mine is the SSG version. I actually wanted the matching normal graphite but it was not available when I bought it. You may want to seal the graphite edges with CA glue.
I personally think that it's the best thing 3Racing did.
Anyway, welcome on board.
p/s: Be careful of the droop screws when you screw into the aluminum piece. You may want to put some loctite thread lock (blue) on it so that it does not come out. In fact, be careful in all the 3Racing aluminum pieces when you thread in the screw. Easily stripped.
InitialD is offline
Old 07-06-2004 | 07:48 PM
  #13618
InitialD's Avatar
Perhaps...
Harder shores can solve the problem quickly. Less caster (more clips to the rear of the front upper arm) reduces on power steering. Try more toe in in the rear to reduce on power steering and stabilise the rear also.
InitialD is offline
Old 07-06-2004 | 07:51 PM
  #13619
InitialD's Avatar
Craig1, nice ! More please.
Perhaps you may want to approach markp27 regarding his patented Photoshop filter to clear the dirt off the car before posting the pics !
InitialD is offline
Old 07-06-2004 | 07:59 PM
  #13620
InitialD's Avatar
Default Re: Assembly Questions
I have no experience on this one as I have not gotten it to test it out. Perhaps Pyramid / Goldfinger can help you with this.
Mugen Super Grease ! Serpent bearing oil is too light. You need a grease that is sticky and will still stick after a long while.
I have not lubed that part. I don't think that part rubs...
I only lube the balls. Put some grease on a tissue paper and rub the balls evenly with the grease so that the balls are coated with a thin and even layer.
Well, mine came like that too. But I think I prefer the method of the rear diff. Somehow the snap ring in the front diff does not fully move the friction collar snugly towards the diff pulley. There is still some play there. Anyway, I still left mine like that and no problems.
InitialD is offline
