Serpent 710
Old 06-22-2004 | 01:09 PM
  #12931
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Winternats 2004
Originally posted by markp27
If I only have to bring over my car and radio equipment
No problem ... I supply fuel and starting equipment ... deal?
Sow&Steady is offline
Old 06-22-2004 | 01:16 PM
  #12932
Sow&Steady's Avatar
Originally posted by Palmaris Europe
Tested this months ago. Ran a full solid bar through the one-way with the outdrives attached to either end. But didnt hold it with set screws. Basically a solid axle with no front wheel braking.
Works great with Lola shells on a tight twisty track.
Ah ... you should show us how it was done.
Old 06-22-2004 | 01:25 PM
  #12933
Sow&Steady's Avatar
Not sure why but the Shark pipes were not working here on the JP or Novamega engines. Totally killed the power and sent the temps through the roof. Stopped some engines from idling.
I've heard that before too. Seems to work best with Rody tuned RBs best. D seems to think it gives more low end and not much top end (with the in-line) and I've found them to give more top-end (with the Outlaw one-piece and an RB 13mm manifold).
Old 06-22-2004 | 01:38 PM
  #12934
teammpp's Avatar
I just got a new camera given too me. Going down town tomorrow to get a USB cable for it and then I will definately put up pictures.
teammpp is offline
Old 06-22-2004 | 02:29 PM
  #12935
Hi
I have just started building my 710 coming from a RR Evo. Looks very good
In the Serpent 710 FAQ, about running in engines, there is a lot of talk about WOT???? What does it mean?
Finken is offline
Old 06-22-2004 | 02:38 PM
  #12936
CraigH's Avatar
Wide Open Throttle?
CraigH is offline
Old 06-22-2004 | 03:14 PM
  #12937
Arun's Avatar
Originally posted by InitialD
So you completed drilling the hole on the driveshaft? Ouch ! Is that the Impact / 835 lightened springsteel outdrives (808223)?
Impressive! Which outdrives did you use? Impact's?
808223 is correct. http://www.mytsn.com/products/product.asp?prid=369
This is actually the second set I drilled. I have been running the first drilled set for a couple of months. Someone else at the track wanted me to drill a set for them, and they already had the spring steel ones, so I offered the 801243 black ones from my axle and drilled the spring steel ones for myself .
Either way...they are much more durable than the stock ones when running a locked front.
This is not what I did at all. I merely replaced the stock outdrives with these.
Arun is offline
Old 06-22-2004 | 03:38 PM
  #12938
Sow&Steady's Avatar
Ah! Don't forget the "other" pictures you promised us ...
  #12939
Sow&Steady's Avatar
Originally posted by Finken
Hi
finken, Craig .. yes, Wide Open Throttle.
Old 06-22-2004 | 03:41 PM
  #12940
Sow&Steady's Avatar
Thanks for the link ...
Oooo ... sneaky. there has to be reward for the hard work somewhere I guess.
I see ...
Old 06-22-2004 | 04:49 PM
  #12941
Wap
hey guys is there some where i can buy a dvd of some of the big national races. I would love to get a whole series on dvd to watch.
Wap is offline
Old 06-22-2004 | 04:55 PM
  #12942
Suspended
Default Re: Re: Winternats 2004
Originally posted by MrChan
I have already watched the DVD. Swauger 1:8th was just fast but not as fast as Raph, Josh or Fukuda. The way he was driving on the stand was quite funny ... But his 1:10th was very fast and expectly long straight ......I just wonder what the engine he used ?
my copy is on the way!!
SERPENTFREAK69 is offline
Old 06-22-2004 | 04:56 PM
  #12943
Suspended
Default BRUCKNER
go to www.brucknerhobbies.com they have a huge selection of dvd's including the new winternats 2004 ken
Old 06-22-2004 | 06:50 PM
  #12944
cyba888's Avatar
You can try here.
I'm not aware of this. If you got the inline one, you could adjust the pipe length via some teflon inserts. If you got the two piece pipe version, there is an outlaw and legal version. You need to purchase a separate manifold for it.
D, thanks for the link. I have the MAX P5 engine so I am hoping it should run good with it.
cyba888 is offline
Old 06-22-2004 | 07:11 PM
  #12945
For high speed tracks, the newer Nova based pipes are excellent. For short tracks, the Shark pipe gives very good bottom end torque.
Hi D,
i agree that the shark pipe is very good in bottom but did you encounter the pipe was very high fuel consumption ? I used shark but end up it could only last 5 minutes, that is my concern. i am not only the one who have had this issue.
speedy100 is offline
