Old 06-20-2004, 10:07 PM   #12781
cyba888's Avatar
Originally posted by GoldFinger
Why is your car in "off-power" condition when exiting corner ?
Oops I meant entering corner...
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 06-20-2004, 10:08 PM   #12782
Car Breaker's Avatar
Eventhough I have all the #mm screws sitting at home, I still having trouble finding those screw uses under the chassis.
Where can I find some 3.5mm hex stainless steel or titaniun screw to replace those under the chassis?
Car Breaker is offline   Reply With Quote
Old 06-20-2004, 10:12 PM   #12783
Pyramid's Avatar
Originally posted by cyba888
BEsides drag brake what other options can I play with? To solve the problem am I suppose to have more traction in the rear, if so then that would take some of my steering away correct? I dont want to lose more steering.
Sorry, maybe I got what you meant wrongly.. Why you need more rear tracktion.. when the car is understeer?
Pyramid is offline   Reply With Quote
Old 06-20-2004, 10:17 PM   #12784
Pyramid's Avatar
I see.. if other condition is ok with you, definetely try drag brake by putting shorter sping (then the one on throttle) with medium tension (like 50% less tension than the throttle) and adjust to have drag brake as hard as possible without the rear slips when off throttle entering the corner. You`ll like it.
PS: On the brake lingkage, after that shorter spring, I add about 1.25cm silicon tube before that plastic end screwed in.
Old 06-20-2004, 11:34 PM   #12785
cyba888's Avatar
Originally posted by InitialD
Try to mount the rear shocks one or two holes more vertical. You could also try 37 shore rear tires. 37 shore rear and 35 shore front should balance the front and rear tire wear nicely.
Will try that next time...Thanks
Futaba 4PX
Old 06-20-2004, 11:40 PM   #12786
cyba888's Avatar
Do you happen to have a pic of how yours is setup?
Futaba 4PX
Old 06-21-2004, 12:09 AM   #12787
Yah... you must copy from the 'right" guy.
Yesterday he was TQ and winner on our State TC III.
Im only qualified 2nd and finished 5th.
Damn !! Pavel Nedved play amazingly to drove Czech through next round.
GoldFinger is offline   Reply With Quote
Old 06-21-2004, 12:21 AM   #12788
Pyramid's Avatar
On the brake linkage.. there is short medium tension spring and silicon fuel tube before plastic end. Why shoter spring than throttle? because when using longer spings, your throttle springs will reach dead end first before maximum brake. Why +silicon tube, because the shorter spring on brake wont be long enough to reach the end threat of that plastic end on brake linkage. I urge you to try it.. it will sure make your driving much faster.
PS: Lower front shore would definitely works to gain more front traction. I`m just having a really bad bad bad experience with it on our National championsip. Since between lower and higher shore rating would react differently in different temperature, that was disaster on the condition I was running on final (tarmac temp varies within 15deg C on and off in 45 minutes).
Old 06-21-2004, 12:27 AM   #12789
crashed_1's Avatar
hmmmm.. this is new, even when I`m running with old belt (loose) it still never get out from the pulley.
New for me too. Unfortunately i found out during a race. Stuff like these never happen during practise...
crashed_1 is offline   Reply With Quote
Old 06-21-2004, 12:29 AM   #12790
cyba888's Avatar
[QUOTE]Originally posted by Pyramid
[B]
Thanks for the pic...that is one sweet looking car
Futaba 4PX
Old 06-21-2004, 02:17 AM   #12791
InitialD's Avatar
Congrats both on a good run.
Old 06-21-2004, 02:22 AM   #12792
InitialD's Avatar
Anything that does not happen normally will happen during race day. That's the rule of racing.
Old 06-21-2004, 02:26 AM   #12793
InitialD's Avatar
Whoaa... Picture of the mother snake ! Congrats on the TQ and your win !
Well, I tried the spring method on the brake linkage as well last weekend. Works quite well with a oneway and I was pretty impressed. I think I just need to shorten the spring. Like you say, the spring on the throttle was a little shorter than the one on the brake linkage. Unfortunately, I was too chicken to race with it. Long track with elbow hairpins at the end meant that you need brakes especially with many cars on a narrow track.
I swapped the oneway with solid front axle with the pins and did not change any setup on it. Brakes felt nice. Had to bump up the EPA on the brake servo a lot but the car did not brake abruptly because of the spring even at last minute braking. Very smooth and during the 4 wheel braking, the wheels did not spin. It's just like ABS on a real car.
Bro, we have mostly hot climate tracks here. A friend of ours drives with the best tire brand and found the traction to be inconsistant. I think he was using 37 or 35 shore. When he used another brand which was 40 shore for the final, he found that he could drive more easily with it.
Old 06-21-2004, 02:36 AM   #12794
As always.. thanks bro!
I dont see your name on the Malaysian registered racer for Jakarta Open ?
Did you change your name recently ?
Old 06-21-2004, 03:58 AM   #12795
InitialD's Avatar
Oophs...
