Serpent 710
Old 05-26-2004 | 10:30 PM
  #11431
InitialD's Avatar
Originally posted by Pyramid
Futaba Jakarta Open, conform schedule on July 10-11 with as of today conform 33 International drivers from Brunei, Singapore including Hobby Link owner, Thailand including Surikarn and Suruth, and other neighboring countries. Dont miss it and do register as early as possible.
I'll try and look for that free date and see if my "wingman" would want to make it to. But the participants look intimidating.
InitialD is offline
Old 05-26-2004 | 10:39 PM
  #11432
PSI Racing's Avatar
Originally posted by InitialD
Damn. You make me feel like a wanted man. Kinda like Zorro except with no horse !
Zorro with a 710 and a 3PK.
PSI Racing is offline
Old 05-26-2004 | 10:43 PM
  #11433
markp27's Avatar
and not forgetting the items mentioned in the FAQ
markp27 is offline
Old 05-26-2004 | 10:46 PM
  #11434
InitialD's Avatar
Not forgetting FAST servos too.
Hey, have you got around to comparing the 2343 and 2344 yet?
InitialD is offline
Old 05-26-2004 | 10:48 PM
  #11435
InitialD's Avatar
What???
InitialD is offline
Old 05-26-2004 | 10:52 PM
  #11436
PSI Racing's Avatar
Obviously we can't possibly comment on the allegations of D's name, i.e. "you may very well think that, but I couldn't possibly comment"
Is that like a "Don't ask, Don't tell" policy?
You could neither confirm nor deny.
Old 05-26-2004 | 10:55 PM
  #11437
PSI Racing's Avatar
Nope, not yet.
I'm looking to invest in a new engine.
So my money needs to be spent on that instead.
Old 05-26-2004 | 11:05 PM
  #11438
PSI Racing's Avatar
The Rx on my 705 isn't PCM - big mistake, but I was young and innocent .... ok younger!
I'm going to order one to avoid this happening again.
Yeah, it bent just after the last non-bumper retaining screws on the chassis, so it is just the very tip - a hit with a hammer should do the trick
I had my Impulse chassis bend at the same spot.
I fixed it with a hammer.
This happened back when I had it setup for the lola body.
I cut the upper bumper plate to fit the lola body, and it was no longer secured to the lower bumper.
I guess without having the upper and lower bumpers connected, it puts all the impact on that part of the chassis.
Old 05-26-2004 | 11:42 PM
  #11439
Herbie's Avatar
Disaster at the track tonight whilst I was testing my 2106 - somehow my crystal came out of my reciever - car went wild - full throttle across the track into the fence *ouch* bent the front part of the chassis up and it seems like the rx unit has died hope the motor is ok, as it was on full revs for about 20 seconds
Motor was excellent when it was running @ 130 Deg C - hot!!!!! but the LSN tuning seems really critical - I eventually had it turned out 1.25 turns and then I could pull away nicely and not have the engine keep cutting out!
Oh man - I'll have to see if I can rescue the chassis some how - it's the 705s 4mm one, so maybe I can bend it back into shape. It's only the very end which is bent up. Are these things fixable?
Sorry to hear Mark hope your motor will be fine otherwise your fx wil have a hard time running in both cars Didn't you have a failsafe ( elastichairbandthingie ) around your carb. Works fine for me and it keeps the carb closed when something happens.
I see that you also like to run your engines hot
Herbie is offline
Old 05-26-2004 | 11:46 PM
  #11440
Herbie's Avatar
Thanks Mark.
Is that "D's" real name?
Maybe we might finally uncover the man behind the mask.
I think so yes
Herbie is offline
Old 05-27-2004 | 12:14 AM
  #11441
markp27's Avatar
The problem was when the crystal fell out, the servo pushed to full throttle - the fail-safe elasticband/spring wouldn't have helped. I'm going to replace my RX with a PCM version, so I can have a built in fail-safe.
markp27 is offline
Old 05-27-2004 | 12:26 AM
  #11442
Herbie's Avatar
I use the Helios but with no failsafe only the elasticbandthingie but I don't have that powerfull servo's on my 710. For throttle/brake I have a hitec 525 BB and my steeringservo is a futaba 9202. I must say that the rx from Ko Propo is the smallest I've seen it fits the recieverbox of the 710 very good.
Herbie is offline
Old 05-27-2004 | 12:52 AM
  #11443
Sow&Steady's Avatar
Originally posted by GoldFinger
I like the way you express it all in a clear crystal fashion!
Uncle Sow, sorry to use your statement.
This morning, my partner is in "healthy" condition.
No problemo ..
Sow&Steady is offline
Old 05-27-2004 | 01:02 AM
  #11444
Originally posted by Sow&Steady
No problemo ..
So now you stay in England ooo?
GoldFinger is offline
Old 05-27-2004 | 01:07 AM
  #11445
Sow&Steady's Avatar
Nice Snake Blade there!!! Who' is it?
Yeah but I bet she had the best time of all! This is a baby water snake !
