Serpent 710
Originally posted by PMR
I'm inetrested with the topic you post in serpent's website regarding the modified flyweights. My question is, when you cut the shoe into three pieces what do you use? Dremel? Cutter?
Originally posted by PSI Racing
I just used a normal X-Acto nife.
Originally posted by kreidel
Do any of you guys have a problem with the front pillowballs pulling out of the hub carrier?
Also, has any company made front swingshafts/cvds that are any good?
Originally posted by Sow&Steady
Good luck man ... and don't ... erm crash!
Lesson No.1...PRACTICE PRACTICE and PRACTICE. Damn what a shitty day i had...My engine overheated on Heat #1...flamed out and couldn't get it started. Heat#2 richened the engine and 2nd gear wouldn't kick in...then cartwheeled 6 rounds and the shocks popped out. Heat #3 was okay but not good enough, engine flamed out and restarting took a while...landed in C main.
Wrong tyre choice saw me understeering all over, and the worst bit was lack of practice...
Overall it was a fun race but one i'd like to forget.
Originally posted by InitialD
No. Are you clipping the curbs? My guess is that if the pillow balls don't pop out of the hubs, you either snap the pillow balls or rip the pillow ball out of the arms.
The 3 Racing one is just so so.
Originally posted by Palmaris Europe
Already have done. The joys of Broadband. Shame Sam caught the curb or she might well have gave Mark a good run for his money. That seemed to throw her off the rythym a bit.
Originally posted by SupermaxxRich
Started the car up and drove it lightly around, put the brakes on and it spun out like I had a oneway in it?
Went down the straight and started accelerating hard and it pulled hard to the left.
The front on the other hand was very tight even with the adjuster coller on the diff set all the way loose?
My guess is that when you took it out and loosened the diffs, the screws were not set correctly. If you did it not correct, loosening the diffs would make the pulley slip.
Shut the car off, apply the brakes and noe I can spin the front pulley just like a oneway?????????
I don't know what to do? If I set the screw in the middle of the diff tight enough so that the pulley doens't spin by hand its very hard to turn the outdrives. If I loosen it enough to free up the outdrives the pulley spins?
I had to let off the throttle half way down the straight in order to be able to slow down enough in time to make the corner.
I don't know what to say about today but I need some advice before I flip out!
I used a Synthetic Automotive grease for the bearings, made sure I packed them good. Shimmed the Centax to perfection with a set of $200 digital calipers. I set the Centax to 0.5mm endplay and then set the total end play to 0.1mm endplay.
The only thing I can think about that may have caused this was that my clutch spring was a little tighter than it should have been and it took quite a few RPM's before the clutch would engage, maybe I over heated the bearing?? Its all stock the Centax III, nothing has been modified.
The guy that had that smoking fast 710 told me that he doesn't use grease on his diff balls, he finds the diff works better this way and lasts longer as well?
One other thing I tried when I still had the front diff in my car and it was quite hard to turn the front tires I figured I'd try to make the back almost as tight as the front, well that didn't work either car still spun out when hitting the brakes.
I'm also going to gear my car for quicker acceleration, the guy with the yellow 710 told me what gearing he was running so I'm going to go and get me some pinion and spur gear sprockets.
Let me clarify this, does removing the front sway bar or lessoning its power like going from 90 degrees to level make the car have more steering or less?
Originally posted by crashed_1
Ermmm...that's exactly what i did.
If its one of Tomato Fattini's "closed" races then give me your equipment, you need to retire and just spray paint bodies for us.
Originally posted by markp27
Not sure which system the R40 uses, but the Centax III requires more precise setup than the older Centax versions - the Centax II was pretty much fool proof - you could set it up quite badly and it would still work ok. The centax III requires much more precise setup to work well.
A tight front diff should give you plenty of brakes, so that shouldn't make you spin out - have you adjusted your brake power on your Tx unit? Maybe it is set too high and is instantly locking up all the wheels.
Perhaps the car is slightly tweaked. Shocks lengths are not set correctly etc.
Strange. Your engine is the least of all that would flame out. Evidenced in all the weekends we've played !
What mod?
I don't think there's any solution at the moment...
What mod?
It was the crunching of the blade running along the bottom of the bones in the hand that was unbearable.
