Old 05-04-2004, 08:46 AM   #9421
Sow&Steady's Avatar
Default Re: Re: 3Hobby.Com
Originally posted by PSI Racing
How do you become a registered user?
Do I just type my nickname, password and security code?
Ooops, sorry ... good point.
If you look at the sidebar on the right, it says something like "You can create one." Click on the words "create one" and it takes you to the registration page.
Or just click here.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 05-04-2004, 08:49 AM   #9422
Sow&Steady's Avatar
Default Re: Re: Re: 3Hobby.Com
Originally posted by BaxterC
Hi there, Click on 'Your Account' and then you will be able to click on a link that says 'New User Registration'... Thats what I did.
Thanks BaxterC, appreciate your support!
Once you join, you can post on the forums, look at everything in the gallery including creating your own personal albums, post news, articles, check out weather forecasts before going racing etc.
In your own page you can change the look of the website, look at news from other sites and customize your own links. I've added RCTech to mine and also in the main links page.
Have fun!
Old 05-04-2004, 08:56 AM   #9423
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: 3Hobby.Com
Cool, I was also a bit confuzzed but figured that I will go there and see how it goes... It is a GREAT Site. I hope there will be THOUSANDS of videos of cars going fast with screaming engines... I dont know about you guys, but I dont like guys burning their cars and jumping them over their houses and things, but that is my opinion. I dont mind them being their though, I just dont download them.
Agree with you there!
I have some videos in the works but still figuring out how best to put it on the site so that it is easy and pleasing for everyone.
I'm also looking at a way to allow registered users to upload videos and/or files.
Thanks for the feedback about the confusing registration link. I'll work out something as soon as I can.
Old 05-04-2004, 09:04 AM   #9424
Sow&Steady's Avatar
Originally posted by markp27
It is a really nice track - it's miles away from anywhere, so I can run anytime I wish - as long as I can see the car, that is. Actually there will be a night race this year - the track will be flood lit
Looks like it was meant for 1/4 or 1/5 scale?
Old 05-04-2004, 09:17 AM   #9425
markp27's Avatar
Send a message via ICQ to markp27
He better, Thank you... I cant get over how small, compact and perfectly assembles the box it, I am scared to take anything out as I may damage the box... jokes. But I can say that the quality of the parts is absolutely briliant. I think it even has the new rear shock tower.
My advice is to keep the box - I have mine pack full of spare goodies. It's a nice easy way of keeping all relevant things together when I go to the race track. Of course I also have my tool box with all my tools, oils, hudy, etc.
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 05-04-2004, 09:23 AM   #9426
markp27's Avatar
1/5th - something I can't get into - they sound like lawn mowers. After I had run my engine in on Sat, I was getting it up to temp at half throttle, when along came on of the 1/5th guys. He dissmisively said, "is that all its got!", no I said and gave it briefly WOT - he had to back off because of the noise
A lot of the 1/5th guys look down on the 1/10th and 1/8th - god knows why!!!
Old 05-04-2004, 09:30 AM   #9427
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
we had a few 1/5 th scales at our track and after one day they never came back , they were running almost 25 second laptimes while the 1/10 th and 1/8 th sclaes were running in the 16 and 17 seconds, and the 1/5 th scales do sound like lawn mowers!!
Old 05-04-2004, 09:33 AM   #9428
markp27's Avatar
On Saturday I had to run with the 1/5th and it was pretty dangerous. We were taking alternate goes on the track with the 1/8th guys - those guys are too fast for me to mix it and therefore I prefered to run with the 1/5th. They were so slow through the left kink, that I nearly ran into the back of the each time through. I ended up running pretty slow times due to this.
Hopefully, if the weather is good tomorrow, I'll get the track to myself
Old 05-04-2004, 09:54 AM   #9429
markp27's Avatar
Default Working out the angle of the cone!
Hi Guys,
If you've got a tyre truer and want to cut down some tyres which already are coned AND you wish to keep the cone angle the same, then here's what to do:
Measure the largest diameter of the tyre at the outside edge. Measure the smallest diameter of the tyre at the inside edge. Subtract the two and call this A.
Now measure the width between where you took the two measurements - not the width of the tyre, simply the distance between the two measured points. Call this B.
Now, go and get a scientific calculator (or use the one on your computer) Divide A by B and then press the "inv Tan" or "Tan -1" button. Divide the value by two and the resulting value is the cone angle. You can now set up you hudy with this angle and cut down your tyres to the desired diameter.
NOTE! When you've set the hudy up to cut at an angle, the diameter setting is no longer accurate - it's best to set the diameter 2 to 3mm larger than you want and then measure the tyres after they are cut. If they are too large then reduce the cutting diameter accordingly.
Hope this helps, Mark.
Old 05-04-2004, 10:21 AM   #9430
markp27's Avatar
Talking Silly question
Should I be measuring the track width with the car sitting on the setup board or by holding the car in the air, as it were?
Old 05-04-2004, 10:49 AM   #9431
Super Moderator
Marcos.J's Avatar
hey BaxterC here are some pictures of my 710!
Old 05-04-2004, 10:57 AM   #9432
rwisejr's Avatar
Send a message via AIM to rwisejr
Nice Mr Marcos .How do you like them monotuning tires?
rwisejr is offline   Reply With Quote
Old 05-04-2004, 11:00 AM   #9433
Super Moderator
Marcos.J's Avatar
I wouldn't run anyother tire ,they are awesome!!!
Old 05-04-2004, 11:06 AM   #9434
rwisejr's Avatar
I wouldnt run anyother tire ,they are awesome!!!
cool glad to here that I have few sets tat I ordered from http://www.kinetixrc.com/ an I hope to test them this weekend .The rims seem to be alot stronger than the ellegi's I was using.
Old 05-04-2004, 11:08 AM   #9435
Super Moderator
Marcos.J's Avatar
I think that they are too!!
