Serpent 710
Originally posted by markp27
But, I still can't figure out how you are online so long
You normally start posting @ 04:00 CET and still post at 21:00 CET
You must sleep sometime
You know when your reading somones setup and it says front diff- med/hard and rear diff- light. How do you tell what is Medium or Hard??? I guess its just a "FEAL" thing, hu??
Or is there some kind of science behind it?
Set it reasonably loose. Front slightly tighter than rear. Then put the car on the track and drive. If your car turns too easily, tighten up the diffs. Front being tighter than the rear. Put them on the track until you find that you loose traction. Then loosen it. Depends from track to track. Tighter diffs for high traction and loose diff for low traction.
The first time I held Michael Salven's 710, I could not fathom how he could drive with the rear diff set as hard as a solid axle !
This with +1 rear toe in. I guess it depends very much on car setup and driver. Usually, a loose rear is easier to drive.
Originally posted by Voodo_Magic
Just because its purple and by serpent!
http://rc-mushroom.com/product_info....5fdcf6a49406e0
That is of course purest serpent purple - very expensive element and had to extract from the snake!
Mark what time is it in germany?
I'm a bit of an early riser, you could say - normally not quite that early but generally around 05:00. It must be about 18:30 or 19:30 where you are?
Now it is 06:28 - been up since 04:30, though
