Serpent 710
Old 05-04-2004 | 12:40 PM
  #9436
Julius's Avatar
Default Re: Silly question
Originally posted by markp27
Should I be measuring the track width with the car sitting on the setup board or by holding the car in the air, as it were?
Car on the board, as you run it.... Normally anyway
Julius is offline
Old 05-04-2004 | 12:41 PM
  #9437
Julius's Avatar
Default Re: Working out the angle of the cone!
Hi Guys,
If you've got a tyre truer and want to cut down some tyres which already are coned AND you wish to keep the cone angle the same, then here's what to do:
Measure the largest diameter of the tyre at the outside edge. Measure the smallest diameter of the tyre at the inside edge. Subtract the two and call this A.
Now measure the width between where you took the two measurements - not the width of the tyre, simply the distance between the two measured points. Call this B.
Now, go and get a scientific calculator (or use the one on your computer) Divide A by B and then press the "inv Tan" or "Tan -1" button. The resulting value is the cone angle. You can now set up you hudy with this angle and cut down your tyres to the desired diameter.
NOTE! When you've set the hudy up to cut at an angle, the diameter setting is no longer accurate - it's best to set the diameter 2 to 3mm larger than you want and then measure the tyres after they are cut. If they are too large then reduce the cutting diameter accordingly.
Hope this helps, Mark.
You could also:
Put the tire on the setup board and take a camber gauge and measure how far it leans over. The calculator look much cooler though
Julius is offline
Old 05-04-2004 | 12:49 PM
  #9438
markp27's Avatar
Default Re: Re: Working out the angle of the cone!
Originally posted by Julius
You could also:
Man, why didn't I think of that That's what you get for studying Physics!
markp27 is offline
Old 05-04-2004 | 12:53 PM
  #9439
markp27's Avatar
markp27 is offline
Old 05-04-2004 | 01:13 PM
  #9440
markp27's Avatar
You could also:
Julius,
If the coning shows that one side has 1 Degree more coning than the other and both sides have equal camber, that should mean that I should alter the camber on one siide to get the optimal camber setting?
Cheers, Mark.
markp27 is offline
Old 05-04-2004 | 01:26 PM
  #9441
Julius's Avatar
Default Re: Re: Re: Working out the angle of the cone!
Julius,
Cheers, Mark.
Yes, you want to get both sides close. Sometimes you will have extreme corners (like the corner onto the straight at heemstede) which make getting both sides equal very difficult. I usually don't run more than 1 degree difference and accept if there is still a difference.
Julius is offline
Old 05-04-2004 | 01:28 PM
  #9442
border r/c's Avatar
Default Nice Body
Julius you've been in the plane too long - you're out of data, man! Check my last picture from yesterday:
http://www.rctech.net/forum/attachme...&postid=860272
The ti-screws are all from Tamiya - I ordered them from rccarinternational.com - you can probably go to the shop to have a look. They are true M3 screws with the 2mm hex button heads. Also I've got some M3s with counter sunk heads. All tamiya. Expensive and not so much weight saved
Cheers, Mark.
Hi Mark, very nice body
try the New enneti disc wheels there real good New super foam !
about the lay down conversion sets for MTX3 and 710 were getting them soon
thanks for your help (nice decals )
border r/c is offline
Old 05-04-2004 | 01:42 PM
  #9443
markp27's Avatar
Default Re: Re: Re: Re: Working out the angle of the cone!
Julius, reserve me a place at your circuit - I'm on my way!!! That circuit looks fantastic! In someways a little similar to mine, in that there is one longish fast corner, a long fast straight and lots of very tight corners.
Cheers, Mark.
markp27 is offline
Old 05-04-2004 | 01:44 PM
  #9444
markp27's Avatar
Default Re: Nice Body
Thanks Those decals go really well with the colour scheme
I'm placing an order soon, so I've got some spares for my engine - I'll take a couple of those wheels at the same time
Cheers, Mark.
markp27 is offline
Old 05-04-2004 | 01:47 PM
  #9445
markp27's Avatar
Yeah, the figure was a bit extreme, but what I'd meant to ask - if the difference was one degree then that would mean the camber on that side should be adjusted by one degree? Hypothetically speaking?
Cheers, Mark.
markp27 is offline
Old 05-04-2004 | 03:16 PM
  #9446
KevinS's Avatar
Most alu screws are the countersunk type and I don't want to use the shims underneath.
Have you tried www.fastener-express.com ?
They also have aluminum buttonhead and sockethead screws in many lengths packed per 50. Both M3 x 0.5 and M4 x 0.7.
KevinS is offline
Old 05-04-2004 | 04:55 PM
  #9447
Hey Julius, on a track that big. How do you even see your car???
SupermaxxRich is offline
Old 05-04-2004 | 05:17 PM
  #9448
Sow&Steady's Avatar
1/5th - something I can't get into - they sound like lawn mowers. After I had run my engine in on Sat, I was getting it up to temp at half throttle, when along came on of the 1/5th guys. He dissmisively said, "is that all its got!", no I said and gave it briefly WOT - he had to back off because of the noise
A lot of the 1/5th guys look down on the 1/10th and 1/8th - god knows why!!!
Neither me, after I saw some 1/5th cars driven in Malaysia. Definitely sounds like lawnmowers but worse than that they all never seemed hooked up!
Mind you, there is a common thread ... all them drivers seemed to be over 50 so I know we all gonna get there one day. Perhaps its a vision thing?
Sow&Steady is offline
Old 05-04-2004 | 06:40 PM
  #9449
Amazing track !
GoldFinger is offline
Old 05-04-2004 | 06:58 PM
  #9450
rwisejr's Avatar
Thumbs up Re: Re: Re: Re: Working out the angle of the cone!
Sweet track !!!!
rwisejr is offline
