Serpent 710
#9031
Originally posted by Rookie Solara
Anything 3 port and TURBO plug are good...for stock engine, try the NOVA MEGA SX12 SS....1.8HP (they claimed)
Or JP, or Nova MAX....Rody Mod V12....etc
#9033
Originally posted by markp27
Look what has turned up in the mytsn 710 download page:
http://www.mytsn.com/products/downlds.asp?prid=3293
Performance Through Forum-Evolution ...
#9034
Originally posted by PSI Racing
Aluminum Radio Plate Bracket
Aluminum Middle Shaft Bracket
Aluminum Anti-roll Bar Levers
One Piece Engine mounts
Setup Wheels
Setup Wheels
I Just recently installed most (if not all of the hop ups) and made it to the B main at the recently held Speedline race in Las Vegas Nevada, USA.
Josh Cyrul didnt even make the "A" main in sedan and was in my main (Bad Luck) I guess.
He put on a hell of a show against swauger in the "a"main of the 1/8th scale class after 30 minutes they were seperated by about 10 feet, however, Josh got the worst end of the deal and broke leaving Mike Swauger the win !!!!
Swauger is on a roll and watch out, he is a very good racer in the world community right now.
In any event, let me know if you need any of the hop ups which are nothing more than great replacements for items you may break in every day (every race) type of situation.
I found that the Delrin Pivot balls are great because they eliminated the aluminum and plastic ball cup spacer by using a one piece construction element.
The Front and rear body post stiffners are very useful for those
hard to predict encounters with traffic.
By the way, still under weight with alot of aluminum strength added ROFL !!!!!!!!
Scott
SWRC
#9035
Originally posted by GlennCauley
Hi BaxterC,
There are a lot of different opinions as to how to properly break in an engine... almost as many opinions as there are people you ask!
I have tried the slow break-in, idle-through-tanks method, and it resulted in slow engines. I have tried the "break it in the way you will race it" method, and it resulted in very strong, fast engines.
Here is a very good posting about engine break-in:
http://www.rctech.net/forum/showthre...WOT#post811370
Idling a new engine through a tank or two is useless and does nothing to break it in. In fact, it is very damaging to the engine since it results in premature piston/sleeve wear because the engine does not get up to operating temperature.
Hope this helps.
Hi BaxterC,
Hope this helps.
#9036
Originally posted by jfc_tech
thanks...i couldn't wait man, to be called "PAPA!!"
Im planning to buy mini-z for all the boring time being indoor.
#9037
Originally posted by Serpent Nut!
im looking for a good 3port motor that is roar legal, what do you suggest i get? thanks
#9038
#9039
No, the FAQ is now on the 710 download page!
Serpent liked the hints and tips that all you guys have contributed to. Ronald Baar asked if he could place it on the 710's download page
and there it is
and there it is
#9041
If you can get your hands on a KHM NovaMega, better still !
I wonder if Julius gets to run this motor on his 710...
#9042
Originally posted by Marcos.S710
how about O.S. TR , very reliable motor
#9043
#9045
and there it is
and there it is
You should all give yourselves a pat on the back!
