Old 09-29-2004, 07:47 AM   #16531
New_Toasted's Avatar
Location: The Milkyway/Planet Earth/Europe/Sweden/Skåne/Malmö
I've decided to buy a 710 now, so I wonder if there are any cheap, "must have" options? I've thought about this nice new engine monoblock, any opinions?
New_Toasted is offline   Reply With Quote
Old 09-29-2004, 07:48 AM   #16532
Suspended
what do u guys think of the new MEGA engines...will they live up from NOVAMEGA?
SERPENTFREAK69 is offline   Reply With Quote
Old 09-29-2004, 07:49 AM   #16533
markp27's Avatar
Send a message via ICQ to markp27
Originally posted by Sow&Steady
Yeap, its called the Club of the Two Towers! Only then can one have possession of the RING.
Nah a true sign of a Ring holder must surely be the protection of those things which should break
markp27 is offline   Reply With Quote
Old 09-29-2004, 07:53 AM   #16534
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: Optional Servosaver Arm
100% agree ...
Really? Can you post the dimensions? I have the cars but if you've measured it ...
From wheel axle centre to wheel axle centre:
710 258mm
705 256mm (maybe 255.5mm)
Old 09-29-2004, 07:54 AM   #16535
Sow&Steady's Avatar
Well, the FORCE is pretty strong on some days, that's when its OK. On other days, its TOO strong and my car levitates. Its fine when its levitating, the problem comes when it touches earth and again.
I better go see Yoda before I fly back.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 09-29-2004, 07:58 AM   #16536
Sow&Steady's Avatar
Brand new, I can honestly tell you that there is no need for a MUST HAVE option.
If you are an experienced driver, likes quick cornering then the cheapest option is to do the Short Wheel Base mod. Go to 3hobby.com, click on Search and search for "mods". The article title is "710: Mods First".
Old 09-29-2004, 08:00 AM   #16537
Sow&Steady's Avatar
I've not seen one yet. All I know at the moment is that they're cheaper than NovaMegas (if you can find NovaMegas) and that it is the current European Champion with the 710.
Old 09-29-2004, 08:01 AM   #16538
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Optional Servosaver Arm
710 258mm
Thanks ... looks like you've got the RING today.
Old 09-29-2004, 08:03 AM   #16539
markp27's Avatar
So Yoda lives in the USA - no wonder you are there so often
Old 09-29-2004, 08:03 AM   #16540
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Optional Servosaver Arm
Until D turns up and show I'm wrong
Old 09-29-2004, 08:52 AM   #16541
Sow&Steady's Avatar
Old 09-29-2004, 08:56 AM   #16542
Default New Mega's
Hi all,
I have seen the Serent team testing the new Mega (Picco) engine several times at Heemstede (MACH track).
When they use the unmodified version they don't have as much power as the JP FX-03 optioned, or a RB Rody.
When they do run the modified Mega, they are up there when it comes to top speed and power.
The tricky thing with the Mega engine story is that the stock Mega's will be 30 to 50% cheaper as the old NovaMega.
If you go for a MS edition or more you will have to pay just as much as for the NovaMega's.
I think I will go for the new Mega, this because I can modify the engine myself
Julius Kollf his pitman learned me all the tricks to do it the right way.
Thomas
840918001 is offline   Reply With Quote
Old 09-29-2004, 09:00 AM   #16543
Sow&Steady's Avatar
Default Re: New Mega's
Originally posted by 840918001
Hi all,
Thomas
Like they say, if you give peanuts, you get monkeys. No doubt, less money usually means you're getting something less. So, cheaper engines, less performance.
Its a pity that the MS version will be as expensive as the NovaMegas. Errrmmm ... do you do the mods cheaper then?
Old 09-29-2004, 09:08 AM   #16544
Pyramid's Avatar
Default Re: Re: Re: Optional Servosaver Arm
Originally posted by rcpanama
I am using the rod linkage in top with the original servo saver; definitely this will not work because it will hit the ball diff (with 2 piece adjuster install)
It might works if you could find the following item,
http://www.teamxray.com/teamxray/pro...&kategoria=492
Pyramid is offline   Reply With Quote
Old 09-29-2004, 11:17 AM   #16545
Misposted...
