Serpent 710
#302
Originally posted by InitialD
I know nuts about electric but I always thought that a stiffer chassis would be better suited for high traction surface (carpet).
#304
What??,, Michael Salven , here???,, I have to call my friend ,, he is a die hard fan of Michael!!
Agree with you Master D. ,, we need more higher ratios to run in very thight technical tracks,, Some one said that ,, they test the 710 in different tracks,, so, Did you guys (from Serpent) really test this car in thight tecnical tracks?? the 710 would keep up with the Mugens and the HpI's R40 in this conditions with stock spurs and Gears??,,
#305
Originally posted by fmolzer
Do you mean the optional upper deck on the T1? I found that one hard to understand too, but it did help my xray on the carpet track... Go figure.
Good on that particular day? or there isn`t other thing to adjust and must flex the car?
#306
I drove 414M WCR, in very hot (65 deg C) high traction track when I corners hard the tire makes a sound (kkrrreeee..) but some fast (too
) XRAY car does not make that sound in same corner, same tire/insert and they using med flex arm. This reality is haunted me till now. And spawn said that so did masami in his YOK (even it was flex-deck).All this made me very confused, so what good of those "bloody_hell" expensive carbon option for?
And the question is still : Do our legend made this kind of med or flex part as an option ?
#307
Originally posted by Pyramid
Never plays carpet before... but interesting to know...
Back to 710.....
#308
Back to 710.....
Back to 710.....
Perhaps your XRay shocks that you were using were too hard to begin with and that a flexi upper deck was needed to hit the sweat spot... As they say, too much of something is not good. It must be just right and balanced.
#309
Originally posted by Proficar403
Is the cluch bell the same from the centax II to III? I only wonder because I already have the lightweight bell for the centax II on my 705, and thought it would be nice to transfer it to my new car.
Putting the 710 spurs and pinions onto the 705 (if that is indeed possible) yields a 1st gear final drive ratios of 7.63 to 6.56 and 5.43 to 4.78 with the stock 2.0 internal drive ratio of the 705.
With the optional 47/22/17 internal pulleys on the 705 (internal ratio of 2.14), the 1st gear final drive ratio goes up in the range from 8.14 to 7.0 !!
The 2nd gear final drive ratio goes to a range of 5.8 to 5.11.Looks like those ratios are the ones that many people are looking for !
#310
IPerhaps your XRay shocks that you were using were too hard to begin with and that a flexi upper deck was needed to hit the sweat spot...
If already having adjustable damper and wide selection of spring rate to fine tune, why would we need those flexy parts?
Can you guys imagine M. Schumacer driving a "flexy-chasis" Ferrari ??
(no offense just kidding)
D, nice shoot for gearing swap
It would make me more confident with my configuration choice, 705 for Lola, 710 for Touring.
Can't wait for 710 details.....
#311
I always think that chassis flex has always got to do with the relative interaction of the shocks... I may be wrong with this one but for me I use a general rule of thumb that if you use a stiff chassis (like a 4 mm one), you should use softer shocks and vice versa on a medium traction track. Just like the effect of using stiffer sway bars with softer shocks.
Ok, before it gets to far... is there anyone know how much S710 will weight with all regular goodies fit into it?
#312
Just my 2 cents...
#313
Originally posted by paulfitipauldi
:Some one said that ,, they test the 710 in different tracks,, so, Did you guys (from Serpent) really test this car in thight tecnical tracks??
http://www.mrc-oberhausen.de/
http://www.raco2000.nl/fotogallerie/...ausen/016-.jpg
http://www.raco2000.nl/fotogallerie/...20hobbelig.jpg
