Serpent 710
#2522
Originally posted by evlhdlts
what's the deal with the front ball diff?
does anyone know when this will be available?
at our local track, we need a front ball diff bad!!
#2523
Originally posted by InitialD
Which other track is the nearer one, which has pit tables, shaded, reasonable tire wear on 40 shore, relatively clean and pebble free and reasonably big?
#2526
Just drove it for the 1st time. Dusty track at the Las Vegas Silverbowl. I have never had a car feel better, stock out-of-the-box and stock setup!Only problem I'm having is with a soft clutch. I set up 2 engines with their own clutches. One is a NovaMega 2105MS and the other is an RB V12T/Rody> The latter is new, and is what I was breaking in today. On both engines, when I put the clutch together I put the 0.5 mm shim behind the collet, etc. When I got to adjusting the clutch gap, my "A" measurement is 1.8 mm, and "B" was 1.2 mm. The given value for "A" is 1.3 mm. Do I need to go back and put another 0.5 mm shim behind the collet to bring the "A" measurement down to 1.3 mm?
#2527
Jack I believe the answer is yes. I dont own one yet (i'm in no hurry the season don't start here for 3 more months) but brad and tennessee have been complaining about the same thing, they tell me if they loosen the spring to much it bogs the motor, and if to tight it takes forever to come on. Still havent decided what to do about it yet. Their going to play with different clutch springs first
Don't worry a red disc will come along soon. they always do.
#2528
I raced the 710 for the first time today. Track is a medium length asphalt permanent track in San Antonio, with good traction. Previously I have been racing my Impulse pro on this exact track and layout. Today using my 710 my fastest lap went to 16.103 from the previous personal best of 18.213. In the main I made 34 laps as compared to my previous personal best just three weeks ago with the Impulse pro of 29 laps. Both cars were powered with the exact same motor and pipe combination. Needless to say I was very please with my 2nd place finish in the Expert Modified Foam class. This car is exceptional to say the least.
#2529
From: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
I've driven at your track..(very nice..thank you 4 aces)...
what have you driven before the 710?...(for comparison sake)
#2530
I've driven 1/8: vector, vetec, picco; 235mm picco and impact, 2 & 4 wd; 200mm mtx2 and mtx3.
#2531
The 4 aces will always try to make you welcome.
#2533
how did you like the 710 compared to the Mugens..
Thanks..
Thanks..
I forgot, I also had a ntc3. Too fragile. However, every change that Barry Baker recommends for this car makes it better.
As it stand, I think the 710 is a hand-down winner. I'm sure that when I get back from the Winter Nats I'll have 2 Mtx3s for sale.
#2534
Both the Mugen models were easier to build. The Mtx2 was too heavy, and didn't handle well. The Mtx3 is really a good car. Forgiving, and the set up is perfectly reproducable. Still too heavy. By the time you replace all the parts to get it to minimum weight you've changed the CG and created suspension tuning problems. In contrast to Serpent, there are suspension adjustments built into the car which are never explained, either in the directions, or in online sources. Don't get me wrong; both Tim and Robby are personally very helpful when you see them at the races, but this in no substitute for a documented operations manual. It seems to me that factory interest and support for the club racer is non-existant. There are some weak spots in the mtx3, but there will probably be some in the 710 also.
#2535
Originally posted by B
How do you compare the fit and finish quality of the two brands?
I will admit i have not driven the Serpent yet, but i love it so far and hopefully i have found a new home. Time will tell and it is now Mugens turn to release a new car so we will see what they come up with.
SN
Not in a million years... Serpent forever !
