Serpent 710
Old 03-02-2006 | 09:03 PM
  #23026
Racer Z's Avatar
Default REAR FLUID DIFF FOR THE 710
Does anyone know where to get the rear fluid diff for the 710 in the US? Also I heard they have a upgraded 710. Anyone have any pics besides the one they have on MYTSN.
Racer Z is offline
Old 03-03-2006 | 02:02 AM
  #23027
Ridder's Avatar
Do you mean the diff oil or the gear diff??
Ridder is offline
Old 03-03-2006 | 06:01 AM
  #23028
http://shop.the-border.nl/product.ph...cat=81&page=11 <-- Gear diff..
Upgrade car, NO!... team car.. YES! : http://www.mytsn.com/news/publ.asp?pid=11610
_cyclops_ is offline
Old 03-03-2006 | 06:34 AM
  #23029
Racer Z's Avatar
Default GEAR DIFF
Thanks for the links guys. I just ordered my diff today.
Racer Z is offline
  #23030
jag's Avatar
jag
You can get the gear diff from Serpent USA, or have your LHS get it from there.
I believe the upgraded 710 just includes the common upgrades that everybody already uses... no new parts.
jag is offline
Old 03-04-2006 | 01:25 PM
  #23031
Xyvern's Avatar
I just got the rear gear diff. but where do I apply the silicone diff oil
Xyvern is offline
Old 03-04-2006 | 02:08 PM
  #23032
soc123_au's Avatar
undo the 4 screws that hold the 2 halves together, split it open & fill away. 20000 wt x-ray diff oil works nicely on a med traction surface
soc123_au is offline
Old 03-04-2006 | 02:11 PM
  #23033
Xyvern's Avatar
Thank you
Xyvern is offline
Old 03-06-2006 | 05:44 AM
  #23034
captian's Avatar
Originally Posted by ksrcracing
I've run my 705 just 4 weekends
But now I'm so ready for the new car...
you are going to love it
captian is offline
Old 03-09-2006 | 04:01 PM
  #23035
Default Bearings
What do you guys do to recondition your 710 bearings for the upcoming season. I have my car stripped down right now and am wondering what i should do with the bearings? I know some people take the seals off and clean them out and others just soak them in brake cleaner. Any suggestions? I also noticed some of the ball joints are binding now whats the best way to free those up?
Maxx is offline
Old 03-09-2006 | 04:24 PM
  #23036
Sow&Steady's Avatar
With the national races starting again in less than a month, mine is in pieces too. I'll just do the usual with the bearings, seals off, blast with degreaser and then re-oil and re-seal. The rest like the ball joints just need cleaning and a bit of polishing and they're good again.
Sow&Steady is offline
Old 03-09-2006 | 04:27 PM
  #23037
soc123_au's Avatar
I remove all the bearings from the car, then remove the seals. Soak the bearings in Shellite then place on a paper towel to dry. Then replace one seal in each bearing & reoil using inox or Serpent bearing oil. Replace other seal & reinstall into car.
For binding pivot points, polish the metal parts & reinstall. Make sure the caps arent to tight to cause binding.
Old 03-10-2006 | 01:07 AM
  #23038
My first national is 2 april.. that's like, 4 weeks?! I'm feeling the stress already... car is clean but need oil for the gear diff and i'll probably need some tyres
Amazing how time passes by
Old 03-10-2006 | 01:31 AM
  #23039
Sow&Steady's Avatar
As long as you're having fun, its fine ...
... like some said :-
Time you enjoyed wasting,
Is not time wasted.
Old 03-10-2006 | 02:35 AM
  #23040
Is not time wasted.
So true, although i do feel a need to perform at my best at nationals, so some preperations are needed :P
