Serpent 710
The standard bearings that come in the kit are they rubber shielded or metal?
Originally Posted by captian
all rubber except for the streering shaft and the side belt tensioner
Originally Posted by Julius
And the clutch, and the inner bearing of the 2-speed, and the bearing in the diff.
forgot about that but all the bearing on the 2speed are rubber seal except the oneway bearing
Look again. At the flanged bearing inside....
Julius are you using 30,000wt Serpent or Mugen Oil in your gear diff?
Now that we have our own I use Serpent 30000W.
I ran 30000w Hudy oil before. It should be close to 40000w
But the 30000 Serpent oil should be a good setting for most tracks.
Hey guys
Starting back racing again , any must buys i need to get for the 710.
also need a driver as well
mega zx-12 factory setting
hey guys, could someone tell me the factory carb. setting for the mega zx - 12. having serious problems tuning. your help will be very helpful.
