Serpent 710
I recentley bought the serpent cvd's and i like them a lot. The car is much smoother trough the corners.
I heard from a driver, which had used the 3racing and serpent ones, that they both have a different point where they wear out. but he said the serpent ones where better cause you could replace individual parts.
Originally Posted by Julius
I might be biased but having used the 3-racing ones before we had our own, I can say our quality is better.
After that I used dogbones from Kawahara for a while but when Serpent came out with CVDs, I tried 'em and really liked 'em. I've had a few side collisions with a barrier but they have not warped. Very pleased. I only use them in the front. Any advantage to using them in the rear?
Rob
Julius Heemstede Setup?
I''ve gone from racing at a big track with full-throttle sweeping curves to a much smaller one with a lot of tight turns and one really big straight away (it's driving me nuts!!). Grip varies (doesn't it always) and tire wear is high.
I was looking though mytsn for ideas on setups and I came across Julius' Heemstede setup for the transmission: 17/22 vs. 61/55. I get 17/22 and 61 for sure but 55? I tried it and I wonder if I'm doing something wrong. The car doesn't seem to be a lot faster on the straight-away. My understanding was if I go from 60 to 61 my top speed drops but acceleration is better (good in a short track situation since I'll never get to top speed anyway). Going from 56 to 55 though, shouldn't my top speed go up or do I need a really big piece of track to take advantage of that?
I'm using .7mm gap, yellow shoe, normal flyweights (better response on a shorter track), about 1.2-1.3 gap with the hard spring.
Location: The Milkyway/Planet Earth/Europe/Sweden/Skåne/Malmö
Thanks for all info! A last question though, what would you recommend, the 3-racing CVD's or new wheelaxles and dogbones?
i have used 3racing cvd on my 710 for awhile. No problem at all. I guess it really depends on what happen during the collision.
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
another option, RD turbo II. which one do you suggest?
if you are looking for a pipe that takes a even a mild hit...the RD pipe isn't it........they do bend pretty easy.......I've had really good luck with the new CVEC pipe.........(you can check the thread on RC tech nitro section)_..
here is the web site for HARD racing.....they don't show the complete pictures....but the company is nice to deal with...and you can Email them for more info...
www.hard-racing.com
Nick Ko is the sales manager of HARD,team magic(www.teammagic.com.tw) and Kfactory.....
here is his email.... [email protected]
Just to let you know, hudy stuffs below are re?release,
HSP-106000 HUDY DRIVE SHAFT ASSEMBLY TOOL ( 3MM PIN )
HSP-106050 SET OF REPLACEMENT DRIVE SHAFT PINS 3x14 (10)
HSP-106051 SET OF REPLACEMENT DRIVE SHAFT PINS 3x12 (10)
HSP-106052 SET OF REPLACEMENT DRIVE SHAFT PINS 3x10 (10)
But to be honest I never broke a dogbone or a cvd on the 710.
jag
W00000t!
Finally, it's back!
www.hard-racing.com
www.hard-racing.com
thanks harry, finally i ordered both of them
but there'll be some suprize because i got new shark 2505 inline pipe set (5mm) instead of 2503 (5.2mm). i hope i won't have to make modification on sidepulley and it's not gonna gets engine hot as 2503.
by the way do you know why there is no information about 2503 nd 2505 inline pipe set on hardracing website? so interesting
Originally Posted by rcpanama
Can you tell us ho has it for sell ?
Does anyone know when the gear diff will be coming out and if anyone has been involved in testing it?
Mike
Mike
Yuck, a gear diff Mike?? I couldn't think of anything worse!!
After having a gear diff car and continually stripping gears, I love the ball diff, so easy to adjust as well. I would also assume a gear diff would weigh abit more, so more rotating mass.
Well i know that serpent are planning on releasing one and that it works well on slippery tracks. I also know that every car but the 710 uses one.
