Serpent 710
Has anyone ever had problems with motors suddenly going lean after 5 or 10 minutes on the track? It's come in 1st stop at 230 or less and then lean bogs 2.5 minutes later and dies at 3-350. I've switched fuel line, tanks, pipes and motors and nothing has helped. I never had this problem with my NTC3, impulse or vector and I've run out of ideas.
Rtolle:
It looks that you have an air leak , that comes after the engine heat and expand properly. First I will think of resealling back plate, carb etc. Also check your tank. If nothing helo, you probably have a crack on the crank.
Originally Posted by kitracer
I asked M.S... he won't say a word so I am sure something is going on...
ok, i better stop the rumour... haha
Rumours rumours rumours.... Serpent is always testing things.. so there are always rumours... you need to be worried if they are not testing things...
Hi Guys,
It's been awhile since i have looked at the S710. I did get one when they first came out, but i had problems with the clutch and gave up in frustration. I think looking back it was more user inflicted pain rather then anything else...
I am looking at a few options for the 2006 season and wondered if there is anything major that is required after the kit purchase? I do remember breaking a front dogbone in the early stages. But i see Serpent have released CVD's, however i just read that it isn't a good idea to use these with the front spool:S
Also,
Is there anything else required to finish off the rear gear diff (#802600) or is it just add oil and it is RTR?
I have seen things being posted about a new chassis could be released soon, i know Serpent have not commented publicily about it, but RC-Mushroom have dropped the price on the S710 too
I look forward to reading your replies.
H_O
Also,
H_O
Originally Posted by hooked_on
Hi Guys,
All you need is oil ...
The diff's outdrives are even supported by ball bearings ... I don't many people noticed that because I've never seen that little fact mentioned before.
H_O
H_O
Hi Guys,
Also,
H_O
Also,
H_O
Thank you guys for your prompt replies
So about from getting CVD's for the front is there anything else i would need before i can hit the track with the stock form kit?
Also,
Is there an overdrive option on the 710? And is it possible for the gear diff to be used up front?
H_O
Also,
H_O
I haven't paid much attention to my 710 for awhile, but need to since I'm heading to the pre-worlds. Tried the gear diff today after seeing posts here and I was able to set my Personal Best. Now I'm all keen again, I better pull it apart and give it a clean.
Serpent is testing other roll centers. So if you see a serpent with some weird looking uprights or stuff, it's rollcenter testing!
We've seen it here on the dutch tracks already, it's serpents way of testing things, they are always testing stuff around at the mach track, really nothing special...
Actually, 2 months before the 960 came out, they where still testing stuff on the 950 car....
So, the new gear diff is here, mine is at the shop waiting to be picked up
Now i still need to find a brand of diff oil, serpent will come with there own diff oil in short time, but for now, we need some other band. From the guys from serpent we here that X-Ray is good.
Mugen has diff oil, but the steps are from 50000 to 100000, witch is rather a lage step, so that brand will fall of for me.
Are there any other brands of diff oil? And if so, are there differences in the quality? (how long do they last etc, etc...) An other thing, how is the pricing/quality/volume ratio of one bottle?
Originally Posted by tommi
I'm having Mugen diff oil of 10000, 30000 and 50000 weight in my tool box. Mugen has got diff oil ranging from 3K onwards; although I vaguely remembered that I saw a tube of 1K diff oil in my LHS, not 100% sure about that.
Also Kyosho made 5k
