Old 08-20-2005, 09:09 PM   #22096
Pyramid's Avatar
Originally Posted by snake_eye
dear pyramid, my kit is newest version which has orange motor mounts etc.. so my tires i used is new version i think.
second, rear upper arms on 1 o'clock, lower arms is on bottom position.
if i put shims under front roll center, this means lowering the roll center right? and if i do that i guess front grip increasing because of lower roll center. and it reduces rear grip?
Hi Eric, there are a lot of discussion behind setups in which I also have my own theory for S710. What you have set your car up now, you have the most front grip but the least rear grip (once again, according to my theory). If you have time, tried what I suggest and see if you like it. Furthermore, when the front roll center has no shims under, it also means to some extends when the arm/suspension compressed, the dogbone will hits/rubs with front upper arms bracket. That is the reason I always use up to 1mm shims only and if more front traction still needed, I will look elsewhere.
You can get more overal grip by using optional 802121 low chassis.
Pyramid is offline   Reply With Quote
Old 08-20-2005, 09:18 PM   #22097
Pyramid's Avatar
And yes Eric, I choose to believe higher roll center = more grip.
Old 08-20-2005, 11:18 PM   #22098
Greg M's Avatar
I tried raising the rear roll centre in practice today and hated it, rear end was very loose, so dropped it right back down and the rear grip came back up, but still needed some more front grip. I ended up increasing the front caster to the maximum and changed my driving style abit. In the end I top qualified and came second in the final. Overall a very good day and some improvement in car set up.
Greg M is offline   Reply With Quote
Old 08-20-2005, 11:49 PM   #22099
Snake-If running smaller tyres on the front doesnt work for you then try 42 or 45 fronts.
Mike
ixlr8nz is offline   Reply With Quote
Old 08-21-2005, 12:11 AM   #22100
aaalp's Avatar
Send a message via ICQ to aaalp Send a message via MSN to aaalp Send a message via Yahoo to aaalp
Just wondering...
What is the meaning of myTSN? What do T.S.N. stand for?
aaalp is offline   Reply With Quote
Old 08-21-2005, 12:58 AM   #22101
Mike
Hi Mike,
If you don't mind me asking, what tyres do you run on the Serpent at Ruapuna? Are you using a Mega? If so, any changes to the gearing?
Thanks,
Trevor
Trevor is offline   Reply With Quote
Old 08-21-2005, 03:16 AM   #22102
T-eam S-erpent N-etwork
Brett.w is offline   Reply With Quote
Old 08-21-2005, 03:35 AM   #22103
Greg M's Avatar
Thought you would have changed your Avatar by now Brett?? Since your now running HPI
Old 08-21-2005, 04:52 AM   #22104
Default Rubber Tyres...
Hy guys ..
I've been reading around... and wanted to ask a few setup questions..
What's your advice on running with Rubber tires !? .. they give less grip then foam ones.. and of course, with a front diff, because with one-way the car will spin on breaking ... at least that's what everybody i know says.....
Any advice on what to do to get the better performance out of the car.. with that kind of tires ?!!?..
Thank you
Rodrigo Meira
RMeira is offline   Reply With Quote
Old 08-21-2005, 07:59 AM   #22105
thank you all for help guys. greg, i'm gonna change front tire size today on track if i find truer. if i can't, i'll use 3racing setup tires, might be a little thin but no problem . pyramid, i'll try what you suggest to me. i hope this will solve my problem. now, i have to find easy to drive setup which includes solid diff. and 21t side pulley.
snake_eye is offline   Reply With Quote
Old 08-21-2005, 08:38 AM   #22106
Pyramid's Avatar
With solid front, try the following setups: http://www.mytsn.com/setups/setup.asp?sid=2942
My setup above was run on very technical track using the following optional items: low chassis 802121 and optional long servo saver. PS: do not copy front and rear camber reading, you need to used your own on your particular track and at particular layout. Just make sure front wear evenly and rear slightly conical (inside).
With 21T, use 3mm smaller front tires.
Old 08-21-2005, 12:47 PM   #22107
thanks pyramid. i'm going to set my car up right now. i'll adjust camber close to original and re-adjust on track conditions. and i'll order low chassis too.
Old 08-21-2005, 02:01 PM   #22108
New_Toasted's Avatar
Location: The Milkyway/Planet Earth/Europe/Sweden/Skåne/Malmö
When I drove last time I noticed that my rear tires were getting conical to the outside, this even with the 3 degree rear camber setting? How far could I go? 4 degrees sound a little extreme to me..
New_Toasted is offline   Reply With Quote
Old 08-21-2005, 03:47 PM   #22109
Send a message via ICQ to _cyclops_
Go as far as needed to get the wear right... i was at the mach track (probably you too) and noticed the same thing...
_cyclops_ is offline   Reply With Quote
Old 08-21-2005, 03:59 PM   #22110
OK, I'll try that.. The track is the pretty big Staffanstorp track in the south of Sweden, the host of the 1:8 A-euros next year. It's nice and flat, but when the temps are high the tire wear is real high too, which you can't understand after looking on the flat and smooth surface..
