Serpent 710
Originally Posted by Ridder
In step 8.1, the first thing that is put on the engine shaft is a washer of 0.5 mm.
Mine has a 0.2mm washer.
What would be the effect of the thinner washer?
A thinner washer here might give to much endplay, so you need a lot of small shims to eliminate this endplay again.....
Originally Posted by rcpanama
Thanks very much Julius I was thinking on the 17/22 61/55 as an option for a short straight with very tide corners, I will try it to see tomorrow I will be practicing.
RCPANAMA
RCPANAMA
Sorry I made a mistake I wanted to say 17/22 61/57
RCPANAMA
Originally Posted by M7H
You mean behind the flywheel?
It's the first thing that goes on the crankshaft: first this washer, then the conical thing.
Originally Posted by Julius
In the end it's the combination of washers behind the flywheel and on thrustbearing carrier together that set the endplay. I use a 1mm shim between the cone and the engine bearing so I can use less shims on the thrust bearing carrier.
Originally Posted by HELLOkitty
anything i need to look out for,i am about to start building the 710....
Check out Markp27
710 FAQ Vers. 2.3 @ http://3hobby.net/dloads/710FAQ_Rev2.3.zip
Buyer Beware
i cannot get into it...
I have no problem to get it from rctech
Use rigth mouse bottom and save as
or register at www.3hobby.net and look at download section.
Buyer Beware
Kit,
i was just moved to this desk here at work,and it is telling me that i am forbidden to go to site..??????
You can get at least vers. 2.2 at the 710 download page at myTSN, if you have problems with rctech or 3hobby. There are not the big difference between 2.2 and 2.3
This FAQ are a very good document.
Luck
Buyer Beware
Sound strange.
Luck
Luck
i cannot find it...
Here are the link to MyTSN:
http://www.mytsn.com/products/downlds.asp?prid=3293
regards
