Serpent 710
Old 12-22-2003 | 01:01 AM
  #1966
InitialD's Avatar
Originally posted by GoldFinger
One more thing, the car weight is 1670 with personal transponder.
Is this without fuel, with bodyshell and tires?
InitialD is offline
Old 12-22-2003 | 01:03 AM
  #1967
InitialD's Avatar
Back View
Thanks for the pics Goldfinger !
I noticed from the rear that you used the shorter upper arm and the highest roll center. How is it different from the stock longer upper arm and roll center setting?
What shore GQ tires did you use?
InitialD is offline
Old 12-22-2003 | 01:04 AM
  #1968
InitialD's Avatar
Im showing what the chassis is made for...
Ouch !!
InitialD is offline
Old 12-22-2003 | 01:27 AM
  #1969
Im no expert to explain this, but this setup is better when you accelerated hard from the apex of hairpin. Maybe because the outside rear wheel camber do keep his neg camber. Try this on your hudy block and see what I mean.
As for the GQ shores, I use 40 FR and RR all the way from the start of heat (10.00) till A Final (15.30). This is why I said this car is well balanced and dont forget to check the tire wear (in my picture). I was miscalculated the ride height. After final the ride height is still more than 4.5 mm, damn!!
1670 gr is race ready condition without fuel.
GoldFinger is offline
Old 12-22-2003 | 01:34 AM
  #1970
Julius's Avatar
I think that is not possible with the suggested link length of 44.5 mm. What length are you using?
I made a mistake.....
The arm needs to be at 90 degrees to the servo not the link. That is the optimum setting to get left/right as close as possible. I'll go back and edit my previous posts.
You may need a shorter link than what is in the manual. If nescessary cut the ball ends and the link a little. Or you could see if you have a 705 rear sway bar link around. They were made with a m3 threaded rod that may provide a way to a short steering link.
Julius is offline
Old 12-22-2003 | 03:28 AM
  #1971
fastharry™'s Avatar
From: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
Scrubbed DRS arm
what exactly happened with the arm..(its a little hard to tell)..did it break,bend?...
how hard was that hit?......That arm was one of my concerns...Esp. when used on USA med tracks with boards...
fastharry™ is offline
Old 12-22-2003 | 03:54 AM
  #1972
whaowhoahw!!! first time playing my 705 without breaking anything..... ran about 6 tanks!! YEAAAAAAAAAAA!!!
I took out the front sway bar.. the car turns MUCH better!! I am also using big fat lola style front bumper... I think it gives the arms/shocks/tires much more protection!!
Yea!! I'll go back to the track tomorrow!!FInaly a day of real fun!!
A quick question though... I my is sliding a bit at the rear... If I don't not want to change tire shore (40/40) and do not want to change spring (Red front/yellow rear) is there anything I can do to make the rear bit onto the track a bit better?
Thanks guys!!!!!!!!!!!!!!!
lawndoggie is offline
Old 12-22-2003 | 04:08 AM
  #1973
You should not worry about the arm, it just scrubbed a bit nothing else happen.
Truly, my point is the 2nd spur gear...
In my opinion, dont use stock aluminium pillow ball for rear joint. The old steel one will holds your rear hub better coz it has longer thread.
I think our concrete wall that surrounding track (only half meter away from asphalt) is more solid than your boards ...
Can you believe if it still break apart ?? We have to repair the 4" tall wall in some corner twice this year.
Old 12-22-2003 | 04:14 AM
  #1974
Release your rear bar too....
Old 12-22-2003 | 06:50 AM
  #1975
ammdrew's Avatar
Company Representative
more rear toe in
ammdrew is offline
Old 12-22-2003 | 06:57 AM
  #1976
Sow&Steady's Avatar
Balance out the ride height and maybe increase number of holes in the rear shocks (?).
Sow&Steady is offline
Old 12-22-2003 | 07:06 AM
  #1977
or get softer oil.. ?intead of more holes
Profoxcg is offline
Old 12-22-2003 | 07:41 AM
  #1978
Julius's Avatar
I agree with goldfinger. Release the rear bar as well. If that makes the rear grip too much, use less rear toe-in.
Julius is offline
Old 12-22-2003 | 07:44 AM
  #1979
Julius's Avatar
Why is your point the 2nd spur gear? Do you mean the 1st speed gear, because it touched the drs arm?
Why use the steel balls? Did you rip out a thread?
Julius is offline
Old 12-22-2003 | 08:25 AM
  #1980
Thanks for all the help everyone!! I'll take out the rear sway bar tomorrow...
That was a HUGE improvement I made on my driving skills yesterday, if I contine improving with this pace, maybe I'll get the 710 in 3 months
